S373D 3 point relief valve location?
   / S373D 3 point relief valve location? #1
Ehanson
Kamloops, B.C.
S373-D
Any one checked, shimmed the relief vale of the 3 point hydraulic pressure, and where is it located?
Thank you,
   / S373D 3 point relief valve location? #2
Looking at my manual, it appears to be inside the case as part of the control valve. I've never had mine off or had to adjust it. Book says not to fool with it unless a facility for measuring oil pressure is available.
OK, What I should do is take a pressure reading when the lift is in relief and see what is there.
Does the manual state a pressure the system has.
49" X 74" EXPANDED METAL RAMP GATE (A54756)
49" X 74" EXPANDED...
2006 GMC W5500 Truck, VIN # J8DE5J16367903094 (A55788)
2006 GMC W5500...
KUOBTA M6800 UTILITY SPECIAL TRACTOR (A51406)
KUOBTA M6800...
TORO MBTX2500 STAND ON DUMP BUGGY (A52705)
TORO MBTX2500...
2012 Freightliner Cascadia - Class 8, 6x4, Detroit DD13 (A52748)
2012 Freightliner...
2018 KENWORTH T800 DAYCAB (INOPERABLE) (A53843)
2018 KENWORTH T800...
