Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #3,751
We won't discuss the added weight of the operator. :laughing:
Not to worry - weight is your friend when you need ballast and traction :D
Nice work with that LS 3000
gg
   / Tractors and wood! Show your pics #3,752
Thanks Hermine!!
Like I needed to spend a couple of days at my son's place clearing his neighbor's oak that crushed the fence.
It was tall enough that it out took a few other trees on the way down. What mess it made!
View attachment 481809 View attachment 481812 View attachment 481813View attachment 481814
View attachment 481815View attachment 481818
My son is a plumber by trade and a lumberjack at heart. He's trying to ask me there in that one shot:
"Are you sure you want to try lifting both those wet oak slabs at once?"
That LS 3000 series isn't supposed to lift that much and maneuver with it but it does....
Uphill & backwards...Every time I doubt the capabilities of this tractor, it shows me that tenacity is it's greatest virtue.
The rears are filled to 3/4 with water. We won't discuss the added weight of the operator. :laughing:
The out come?
No more parking on grass making a mud pit.
View attachment 481820 w/10 yds of crushed concrete View attachment 481821
Wet oak is lighter than wet cottonwood or willow. Once you cut it though that relationship changes fast!
   / Tractors and wood! Show your pics #3,753
Thanks Hermine!! Like I needed to spend a couple of days at my son's place clearing his neighbor's oak that crushed the fence. It was tall enough that it out took a few other trees on the way down. What mess it made! <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=481809"/> <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=481812"/> <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=481813"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=481814"/> <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=481815"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=481818"/> My son is a plumber by trade and a lumberjack at heart. He's trying to ask me there in that one shot: "Are you sure you want to try lifting both those wet oak slabs at once?" That LS 3000 series isn't supposed to lift that much and maneuver with it but it does.... Uphill & backwards...Every time I doubt the capabilities of this tractor, it shows me that tenacity is it's greatest virtue. The rears are filled to 3/4 with water. We won't discuss the added weight of the operator. :laughing: The out come? No more parking on grass making a mud pit. <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=481820"/> w/10 yds of crushed concrete <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=481821"/>
You doubted it's ability to life those 2 rounds? That looks like a 500 pound load and your tractor is rated to lift 2100 pounds.
   / Tractors and wood! Show your pics #3,754
More like a 800 - 1000 lb load ...
What was the diameter ?
   / Tractors and wood! Show your pics #3,755
More like a 800 - 1000 lb load ... What was the diameter ?
My guess was 20-24" basing that on it being about knee height to the guy behind it. I'd also guessed about 48" long.
Edit, going by my guesstimate on size according to log weight calculator your 800 pound guess is pretty close. Still less than half of his full height lift capacity.
   / Tractors and wood! Show your pics #3,756
I've not dealt with a lot of cottonwood, but I don't think I've ever picked up a stick that approached the weight of Oak. Perhaps we're taling about a different tree.
From a Table I found long ago:
SpeciesDry WgtGreen
White Oak2880 - 37104890 - 6290
Cottonwood1730 - 22252700 - 3475
Black Willow1910 - 24503140 - 4040
Dry weights are at 12% moisture Content.
This table did not have Red Oak, but it's generally about 10% lighter than White Oak when dry. I'm not sure how the green Red Oak compares.
   / Tractors and wood! Show your pics #3,757
Two tables with species of wood, showing BTU value, and dry weight (one table also adds green weight).
The Chimney Sweep table is the most accurate I've found. Many other table are compiled from a variety of sources, and the authors may not have corrected for the fact that different sources may have measured differently or used different moisture content.
  • Firewood BTU - CS online.pdf
  • Firewood btu weight.pdf
   / Tractors and wood! Show your pics #3,758
Interesting as just about all I have in California is Live Oak... it is the highest rated on the second Btu chart and people here pay to have it hauled away since the burn restrictions started...
It sure does make a pretty fire...
   / Tractors and wood! Show your pics #3,759
SpeciesDry WgtGreen
The numbers you show are for "dry" wood which shows Cottonwood to be about half of oak.
I am not positive that wet Cottonwood is heavier than wet oak but I know it is very close. It also depends on the time of year. If you cut a live cottonwood during a wet spring it is very heavy, mid-summer it is definitely lighter. Cottonwood has a lot of empty pore space in it that fills with water. If you cut one during a wet spring you can almost wash your hands on the end of it - very different from cutting a live oak.
   / Tractors and wood! Show your pics #3,760
I went on another wood getting trip Wednesday. Here are a few pictures of the day.
As you can see it was a beautiful day and the turning leaves made for some good pictures.
I might have one more day left in me to get wood. It's a lot of work for one old man and his bride.:)
20714 (A55853)
20714 (A55853)
2019 Ford F-350XL (A53314)
2019 Ford F-350XL...
2014 PETERBILT 388 VACUUM TRUCK (A55745)
2014 PETERBILT 388...
2012 Volkswagen Jetta Sedan (A55758)
2012 Volkswagen...
CFG Industrial MH12RX (A53316)
CFG Industrial...
2016 Ford F-450 Flatbed Utility Service Truck (A55788)
2016 Ford F-450...
