fidowanttobe
We use Goldenrod 596-3/4 Water-Block fuel Filter. Spin on type, $29. for the filter and mount. Very happy with them.
That's the same pump I have used for the past 15 years or so. At one time I had the same goldenrod filter (although non water block) followed inline by a spin on water block cartridge. I have since switched to using just the spin on water block filter.
The bowl filter lets you see the junk that it has caught, but I prefer the convenience of a spin on cartridge. I believe either of the goldenrod filters (water block or not) are 10u filters.
Do yourself a favor now and but an auto shutoff nozzle!
I put together a 12v pump from HF and filter apparatus and hose from TSC. Works well. Cheap.
I'll prob have to pick up a few more parts at TSC to complete it. I think TSC sells GPI and Cim-Tek filters. Which did you end up with?
I used to know what the micron rating meant (when correctly described). I believe the old spec (still frequently used to make the filter sound better) is called "nominal" which means a 10u filter will catch 50% of 10u particles. I do know that a 3u filter would have to be pretty large to permit reasonable fuel pumping flow. I had a 3u hydraulic filter on my previous tractor that was I believe 3u (b3) that filters 99.9(9?) of the 3u particles at still only 3 gal per min. The thing was larger than a loaf of bread. Anyway.... I probably shouldn't be discussing things I am not sure of.Thanks for the info. Good to know your pump has been working so well. Is yours in a location that is covered or uncovered?
I keep getting different specs on the micron levels for those filters. Some say 17, some 10 I think I saw one listed 3.
