MAJOR PROBLEM! Kubota L3430 Hydrostat hydrostatic drive transmission issue. HELP!
   / MAJOR PROBLEM! Kubota L3430 Hydrostat hydrostatic drive transmission issue. HELP! #11
Ok it is called a strainer. If u want to send me ur email I will send the picture in the manual. Not much with attachments to web sites. It looks like a bolt would with a head on it. It connects the hst line to the case on the right side. It has two o rings. I thought I remembered a screen or strainer
Greg
   / MAJOR PROBLEM! Kubota L3430 Hydrostat hydrostatic drive transmission issue. HELP! #12
The strainer is documented on page g45 of the workshop manual. Assuming ur model is the one with the picture shown here.
I spent countless hours trouble shooting a hydraulic problem and finally took to repair shop. Turned out one of the lines I had just replaced was blocked (new line). Might be worth checking.
Great advice! I will check the lines before I refill. The lines that are easy to access at least.
   / MAJOR PROBLEM! Kubota L3430 Hydrostat hydrostatic drive transmission issue. HELP! #14
My manual shows a 3410 not 3430. They may have changed many things. My heart was in the right place just my brain so much.
Good luck
Greg
Thanks for the update!
Thanks Greg for the offer but someone else sent me the pdf of the shop manual. I will follow the advise your mentioned
I wonder if we are looking at the same manual. page G45 is something completely different....
   / MAJOR PROBLEM! Kubota L3430 Hydrostat hydrostatic drive transmission issue. HELP! #20
My manual was for a 3410 instead of a 3430. My mistake!
2014 Dodge Charger Passenger Car (A59231)
2014 Dodge Charger...
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
2012 TROXELL 130 BBL STEEL (A58214)
2012 TROXELL 130...
404 (A52706)
404 (A52706)
DEUTZ MARATHON...
Peterbilt Tandem Axle Road Tractor (A47477)
Peterbilt Tandem...
