What type of quick disconnect is this?
   / What type of quick disconnect is this? #1
muttiwilson
La Center, WA
Kubota L3350DT
I recently bought a Kubota L3350 and not sure what type of quick disconnects I've got. Are these ISO 5675 like most? The center stud is unlike most pictures I've seen but it might still be compatible? I need to order fittings for my loader grapple. Thanks!
   / What type of quick disconnect is this? #2
The center stud doesn't matter. What matters is how well the hydraulic end fits into the coupler. You could go and buy two ends from Kubota if fitment is a concern.
   / What type of quick disconnect is this? #3
Those are identical to the ones Kubota supplied in the rear remotes "kit" for my L4330, including the configuration of the center pin. The bulkhead housing is even the same. Mine are marked "Parker 9006-001 YY". I cannot find any reference to this part number on the Parker/Pioneer website.
The male ends they supplied with them are marked "Pioneer 8010-4".
Now that's an answer! I ordered the hoses and I'll pick up a QD fitting from the dealer here and test it out.
THOMPSON F4L 1011 PORTABLE DIESEL PUMP (A51406)
THOMPSON F4L 1011...
2017 Ford F-550 4x4 Cab and Chassis Truck (A51692)
2017 Ford F-550...
2001 INTERNATIONAL 2574 6X4 DUMP TRUCK (A51406)
2001 INTERNATIONAL...
2025 IR UNUSED Hydraulic Breaker (A53117)
2025 IR UNUSED...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
