nortrac 204c, rust in tank
   / nortrac 204c, rust in tank #1
samr12
LAUREL,MS
NT204C
hello,
I have a no start issue spin not start, found rust in tank, pulled cleaned tank, inspect found brass screens in tank and sediment bowl rusted partly missing, ordered new sediment bowl, installed bowl
filled tank with new fuel, now no fuel coming into sediment bowl, any suggestions before draining tank to inspect also then what to look for?
thanks sam
   / nortrac 204c, rust in tank #2
Rust is a killer. You need to clean out the lines as well as the tank and the bowl, and if the bowl was in that bad shape, bad stuff got past it. I'd clean out everything, and maybe replace all your lines. Rust will kill an injector pump very quickly.
Look into an epoxy repair kit for your tank, too.
rust stopped in shut off valve on sediment bowl,checked banjo fitting beyond sediment bowl filte there ok
just cant understand why no fuel in new sediment bowl?
   / nortrac 204c, rust in tank #4
Try cracking a fule line at the injection pump. This will allow air to move and the fuel is fed by gravity not a pump.
   / nortrac 204c, rust in tank #6
Remove the bowl assembly and shoot some compressed air up into the tank/make sure you have a path from tank to bowl. With the bowl/valve off of the tank, do the same thing shoot compressed air thru it toward the outlet port, make sure the valve works and is on. Re-assembled, fuel should flow into and out of the bowl assembly with the valve turned on... then work toward the IP.
On the injector pump there is a bolt with a ring thru it. That is to bleed air. But I believe there is another screen at the inlet to the IP lift pump that you should check. Also look for fuel freely flowing out of the IP end of that hose with the tank valve turned on.
There is also a hand priming pump near that inlet fitting. Looks like a screw-on cap. Unscrew it and it will pop up as a spring loaded hand pump. You should be able to pump fuel thru the filter to fill the main IP body till fuel comes out of the fitting with the ring thru it. You can also loosen the bolt on top of the fuel filter to release any air as you pump the hand pump. Work from tank to IP to purge air until you get nothing but fuel at the ip vent then close it. With the shutoff cable in the run position and speed selector(throttle) at mid range, Loosen the fittings on the injectors and crank till you get the air out of the hard lines and it should start at the next crank:) dont forget to pull the speed selector back to the start position...
2010 Ford Escape Hybrid SUV (A51694)
2010 Ford Escape...
EZ-GO Textron Electric Golf Cart (A51694)
EZ-GO Textron...
2014 Jeep Compass 4x4 SUV (A51694)
2014 Jeep Compass...
2014 Dodge Avenger SE Sedan (A51694)
2014 Dodge Avenger...
2012 Chevrolet Silverado 2500HD Enclosed Service Truck (A52377)
2012 Chevrolet...
2016 Atlas V4 Towable Light Tower (A51691)
2016 Atlas V4...
