Dadnatron
I'm thinking about purchasing a pull scraper/dirt pan and have been thinking about logistics. I've talked with a couple of guys who have one for sale, and they both said loading it would be no problem in that they have excavators and could simply set it on my trailer.
The question I have is about getting it off at my place. How do I set it, so that I am able to remove it with only my 5100e, an FEL, and gravity?
Weight is approximately 4200-4500lbs deadweight. My FEL has lift capabilities of around 3800lbs at pin at full height. I suspect most of my lifting, even just to barely get it off the trailer, would be approximately full height. So I'm not sure either of enough height nor of enough capacity to just lift it with brute strength.
I've thought of building an A-frame between the bucket and a telephone pole, with the pole one the opposite side of the trailer as one leg, leaning and connecting towards the FEL on the other side as the other leg. If I chained it tight to the fulcrum, I don't know whether the bucket tilt hydraulics in conjunction with the pole, could lift it enough to drive the trailer out.
I've also thought the best way might merely be to have it set tongue to the back, allowing me to back the tractor onto the trailer, hook up, and drive it off. This might be the best overall way, but I don't want to assume and be stuck.
Any thoughts?
Any thoughts?
