Smoked Turkey Breast
   / Smoked Turkey Breast #11
It was only an 8" or so truck but that is still a lot of wood for smoking since I use mostly lump charcoal for fuel and only enough fist sized chunks of wood, when I can get it, for flavor. Cherry is good too. Don't have alder around here so I use apple for salmon.
I have a woodworking shop. A chunk of 8" maple run through the bandsaw and/or planer would last for a long time! Hickory is available in stores everywhere as is apple and mesquite. Even seeing cherry lately but I have a pile of that from the shop (I even give it away for Christmas presents).
We just cut down a maple tree out front and I was sure to save the trunk for smoking.
Yup, I use maple for all my smoking other then beef (when I use hickory or mesquite), as that's what I have around my place. I started with a 5 gallon pail of 2" square chunks, and at the end of season #2 I'm about half way through it.
   / Smoked Turkey Breast #13
Poplar makes a pretty good substitute for alder.
   / Smoked Turkey Breast #14
Did you use a smoker or a grill? What wood did you use?
   / Smoked Turkey Breast #15
No shortage of poplar here (I'm surrounded by it...probably enough to smoke every fish in the world). I've read that alder and "popple" are one and the same and it's merely a matter of local terminology. Have to see if "poplar" and "popple" are the same tree (they might be). If so I can quite paying for smoking wood!
Yeah I'm with you; if popple is equal to alder that'll double my free supply of smoking chunks!
   / Smoked Turkey Breast #19
As usual (IMHO) Meathead Goldwin has the last word on smoking wood.
Barbecue Wood & Smoke: Different Types, How to Use it.
Great read...nothing I disagree with other than his blanket statement about the "myth" of meat no longer accepting smoke beyond a certain temp. Early in his article he explains smoke absorption and rightly says it is related to moisture in the meat. I agree. But absent injecting or constant basting of the outside (bad IMHO because that requires opening up the box way too often), as the internal temp rises the outside moisture of the meat will decrease a lot faster than the middle. That's just how meat cooks. But thanks for the post...I learned/confirmed some stuff. Now to experiment with my poplar that I normally throw on the burn pile!
Couldn't find the same turkey breast roast at Costco, so we did a full turkey. 12lbs. Used 3/4 of the brine recipe for the cooler I had and 3/4 of a bag of ice. Took 4 hours on the smoker and 30min wrapped. I was giving thanks for an attatched garage to shelter the smoker from the storm we got!
New Long Forks (A53002)
New Long Forks...
Super Material Lift MH1000 (A53472)
Super Material...
CAT E70B Excavator (A51573)
CAT E70B Excavator...
199049 (A51243)
199049 (A51243)
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
