Need to bore 3-4 ft horizontally for water line
   / Need to bore 3-4 ft horizontally for water line #1
Nic3456
Member
Sunbury,OH
Na
I need to install my water line that is perpendicular with an existing electric line. The current electric is buried 3 feet and I'll be running the water line 4 feet deep. I would rather not dig out a huge hole and expose the whole trench - trying think of a good (and inexpensive)way to just bore the 3-4ft horizontally. I saw a couple of specialty horizontal augers but they were like $300-$400. I only need a 3-4" diameter hole.
   / Need to bore 3-4 ft horizontally for water line #2
Could you rent a trenching machine. If you're only going 3-4' horizontally and 4' deep what and how are you going to connect to a water line without a huge hole.
   / Need to bore 3-4 ft horizontally for water line #3
I'd dig it with a backhoe as close as possible and dig under the line with the shovel.
   / Need to bore 3-4 ft horizontally for water line #4
Waterhose through a pipe and a shop vac? Totally speculation.
   / Need to bore 3-4 ft horizontally for water line #5
Not a bad idea! I'd go more along the lines of a pressure washer with the nozzle hooked directly on the hose without the wand. The hose should be stiff enough for you to get way back from the mud slinging and push it forward.
I'm going to trench about 550ft total and plan on renting a trencher - just trying to find a more simple solution for the part around the electric (I recently had hernia surgery and not supposed to be doing a ton with a shovel)
Have been trying to rent a ride on trencher with a backhoe, but having trouble finding one.
I thought about this, but wasn't sure how quickly it would turn into a giant mess as I'll be in clay at 4 ft
   / Need to bore 3-4 ft horizontally for water line #9
If dug under utilities with minimal shovel work. Being 4' deep and lack of a backhoe makes it a lot easier. The easiest solution ( for your) is to pay some drunk $50 to do it with a shovel.
   / Need to bore 3-4 ft horizontally for water line #10
I have driven a piece of pipe that far before. Thin wall 2" electrical conduit (EMT) with one end pounded flat to a point, the other hit with a large sledge hammer. Make the pipe 2-3' longer than needed, cut off the flattened end and hammer beat end, shove waterline inside. Done.
1992 Effer 7600 2S Knuckleboom (A51691)
1992 Effer 7600 2S...
2017 KUBOTA RTV-X1120D (A54756)
2017 KUBOTA...
2014 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A55788)
2014 Chevrolet...
UNUSED LANDHONOR 5/16" 7' G80 DBL CHAIN SLINGS (A54757)
UNUSED LANDHONOR...
72'' power rake (A53421)
72'' power rake...
