Got the Uh-Oh Call Today
   / Got the Uh-Oh Call Today
I checked the hole today and it was not getting any softer. I can still hear the leak in the basement though. As deep as I dug it is only about 28" down to the waterline as I can measure the height in the basement. How can it be leaking there and not coming up in the hole?
I have walked the waterline and not felt any softspots in the yard. It was all replaced except about the last 50' into the house a few years back because we had a poly connector crack one year which made the front yard a soupy mess and then the next year I had another one crack and I said that was enough and had the rest of the quarter mile line to the city meter replaced. I just didn't want to go through the all the stuff around the house until I had to which I guess is now. In those other leaks I do not remember being able to hear it in the house.
We will see tomorrow morning.
Sorry! Yesterday got real late at work so I didn't get to tell you what happened.
My guy came out and listened in my basement and told my wife that the leak was definitely not far outside the wall. He then used a vacuum excavator to dig down to it. I had never heard of this type of equipment before so I looked it up on the web. The bottom line is that it uses high pressure water to loosen the dirt and then a high powered vacuum to suck up the water and dirt. This was kind of important since he was digging right next to my gas line.
He found the leak - a very small crack in the black poly hose that had been kinked when it was put in and then straightened out but the movement over the years must have caused it to crack. Of course he repaired it and then put some of the slurry back in the hole.
He said that it takes a long time for water to make a soft spot and that he wouldn't be surprised if the water had not followed along the basement wall in both directions. My wife got the water bill today and this had obviously been leaking for a while as it was about 25,000 gallons over our normal usage in the last month. The repair guy said it usually takes at least a month to show up on the surface but he has seen it be much longer.
I learned a lot in this one - like how many gallons of water could run underground without me knowing about it and how to dig a hole safe, fast, and with no mess.
   / Got the Uh-Oh Call Today #13
How long that water runs underground has to do with surrounding drainage. I am betting your house has a tile around the perimeter of the basement. Wouldn't surprise me if you never saw water on the surface.
I fixed a black poly leak for a neighbor in the middle of the yard about 100' from the house. She found the soggy spot while mowing, and the very next water bill showed high usage. No tile in the area to carry the water away, so it showed on the surface pretty quick.
   / Got the Uh-Oh Call Today #14
Where is your water meter? If the water isn't coming into the house, but you're being charged, it must be at the road? My meter is at the house, so if there was a leak outside the house, I wouldn't be paying for the water. Is this not common?
   / Got the Uh-Oh Call Today #15
Its not common for a meter to be on the house where I live. There is a plastic cover out by the road with the meter located under it. Takes a special tamper resistant 5-point socket to open. Everyone in rural areas out here, that are tapped into the water, the meter is out by the road. Been that way every since rural water starting spreading out here 25+ years ago.
   / Got the Uh-Oh Call Today #16
It certainly makes sense. I'm in a rural county, but the meters are in the house and I believe a signal is transmited outside. Just a few months ago my meter was replaced as the battery in it went after ~12years.
Does that mean you can't check your meter? I had a leak in a barn hydrant years ago. I suspected there may have been a problem, and used the meter in the house to determine it for sure.
   / Got the Uh-Oh Call Today #17
They dont "want" you to mess with it. But a 5-point socket/wrench can be purchased, but a pair of pliers also works. They have no issue if you get in there. Thats where the shut-off is. But problems are pretty rare.
   / Got the Uh-Oh Call Today #18
I'm guessing you are right about the drainage tile. 25K gallons of water leaking against a concrete wall is going to show up somewhere. Maybe find the drainage end of the basement/footing drain and you might find your 25K gallons of water. :)
   / Got the Uh-Oh Call Today #19
My water meter is out at the main road where my 1/2 mile long "yard service line" taps off the county utility district main!
   / Got the Uh-Oh Call Today #20
years ago, had a leak near the meter, maybe 100' from house, could hear water running (just me, not wife). Meter was spinning crazy fast, called water company, they were sending a guy out right away to shut water off after giving us advice on where the leak might be... no one came, several days go by and I called again (had called each day) and since I worked with the IT guys, word got to them and the IT director came out in suit, took jacket off, rolled up white shirt sleeves and said, let's get this figured out. He listened and looked at meter, said it could be anywhere but his best guess was close to meter (about 6' deep). He shut water off and we started digging. Dug about 3' diameter hole and when we got to the pipe, found the leak about 18" from meter in gravel. Dirt/gravel was dry 12" above pipe, then it got wetter. They waived the water bill because they did not come when they said they would, even though the leak was mine to find and fix. It turned out to be a 6" split in 1 1/2" poly. He examined pipe closely and said from the markings, it was likely creased slightly by backhoe when being installed and the water wore the crease until it was open.
There was no shutoff between the meter and house, so I had no means to shut it off... we added a large brass shutoff for future problems, but never had another problem while we lived there...
New/Unused 72in Quick Attach Mower King Hydraulic Brush Cutter (A51573)
New/Unused 72in...
New/Unused 7ft 10 Drawer Work Bench (A51573)
New/Unused 7ft 10...
Generac Generator (A51691)
Generac Generator...
2009 Freightliner Columbia 120 Winch Truck, VIN # 1FUBA5CK39DAM2731 (A51572)
2009 Freightliner...
2025 New/Unused LandHero 16in Concrete Cutter (A51573)
2025 New/Unused...
2020 John Deere 8R 410 MFWD Tractor (A53342)
2020 John Deere 8R...
