Genny Transfer Switches
   / Genny Transfer Switches #1
widefat
Central Va
Kubota L3200 Husq GT52XLS Husqvarna LC121P Husq 455 Rancher Stihl FS90 Stihl MS170 99 Ram 1500
What are you using?
I have an 8kw generator that I am going to use to power a well pump, oil furnace, and a couple of other things.
Reliance and Generac seem to be the major players.
Is one better than the other? Experiences?
TIA
   / Genny Transfer Switches #2
I have an automatic now but had a manual switch that I think was made by Square D. It was 2 pole double throw with a safety interlock rated for the load. I gave the thing to my electrician because I didn't want it banging around and almost had to force it on him.
   / Genny Transfer Switches #3
Your cheapest solution is to install one of these: Manual Transfer Switch Kits | Generator Interlock Kit
and wire to an outdoor twist-loc box/plug to match your generator.
A regular transfer switch will need to be rated for your panel (200A ?) and cost $$$$$
The other alternative is to install one of these types: http://www.northerntool.com/shop/to...ontent=48469&gclid=COS2zdH02s8CFQKHaQodwAoE6w
or: Reliance Controls 3 Amp 25-Volt 75-Watt Non-Fuse 6-Circuit Transfer Switch Kit-36HDK - The Home Depot
The last option will require quite a bit of rewiring.
The first option usually makes the most sense for ease and cost.
Paul
   / Genny Transfer Switches #4
I use a simple 6 circuit manual transfer switch, it did involve wiring it into the main panel. The wiring was pretty simple to do. It has worked well for twenty years now. As a matter of fact we are running on it as I write this. They used to make them in six and eight circuit versions. I have a 5KW generator so six circuits is about all it can safely handle.
Power just came back on so I need to go:cool2:
   / Genny Transfer Switches #5
I like and use the commercial ASCO stuff (bought off E-Bay).
I saw that junky Generac stuff fail in spectacular fashion. Practically burned the house down. No thanks.
   / Genny Transfer Switches #6
Im using one of those interlocks right now too. What's nice is you can switch load off and on. The other nice is my wife knows how to do the whole works so can start things up if power goes out and im at work. Like yesterday and today, and yes it's still off mapper. :mad: :)
   / Genny Transfer Switches #7
Generlink has a unit that is fool proof , takes 5 minutes to install and powers everything . The four , six or 8 circuit generator panel is a goofy awkward thing.
   / Genny Transfer Switches #8
Don't buy one of these !!
My house has one. When I bought the place the inspector and I noticed an electrician had a report posted where he replaced a "burned up panel". Both of us wondered why but could not find one thing wrong with the wiring in the house or incoming power, it was actually quite good in fact. Later when hooking up my generator I powered down my main as a matter of practice but noticed that this "interlock" did not fully prevent both PUD power and GEN power from feeding the circuits at the same time. Then I recalled when we looked at the house the previous owner had a brand spanking new generator. So power came back on and let the smoke out of his generator and electrical panel.
So unless you want to risk your generator, electrical panel and maybe A LOT more, I would not install this. It may not always be me that is at home when the power goes out and my wife or kids likely will not be able to make sure the breakers are in the correct positions. I will install a Square D (or other commercial brand) transfer switch at some point.
   / Genny Transfer Switches #9
Ditto on the use of a commercial brand. Spend a few bucks on this purchase.
2013 BMW X5 xDrive35i AWD SUV (A53424)
2013 BMW X5...
2018 KENWORTH T270 SERVICE TRUCK (A51406)
2018 KENWORTH T270...
2011 DOOSAN G25KW GENERATOR (A53843)
2011 DOOSAN G25KW...
2015 Kia Sorento SUV (A50324)
2015 Kia Sorento...
2001 INTERNATIONAL 4700 4X2 SERVICE TRUCK (A52706)
2001 INTERNATIONAL...
