Vibration in Ford 600?
   / Vibration in Ford 600? #1
arrows
VA
N/A
I went to go check out a Ford 600 series today to see if I want to buy it, and when I cranked up the throttle, even just part of the way, it made a loud rattle and lots of vibration. Is that normal, or a problem? It also made some blue smoke from the exhaust for a few minutes, which dissipated after the engine warmed up.
From what I could tell, the rest of the tractor looked ok, but I'm not experienced at all in checking out old tractors.
   / Vibration in Ford 600? #2
hard to tell on a rattle might be the hood sheet metal or fenders. Rattle from the engine usually ain't good
   / Vibration in Ford 600? #3
Often those tractors will have a hood vibe but blue smoke from the engine will likely call for an overhaul. Ed
   / Vibration in Ford 600? #4
a vibration from the engine could be a missing cyl. a good vibe will cause sheetmetal to rattle.
smoke on throttleup is usually umbrella seals. at minor to low-moderate levels, it is merely an annoyance, and higher levels, it can make her smoke so bad it's difficult to use her and keep plugs cleaned, and see thru the clouds of smoke.
   / Vibration in Ford 600? #5
The hoods on mine rattled so bad that it would hurt my ears after an extended time at pto rpm. I put new rubber bumpers under the hood and it is as quiet as a mouse. If you can feel the vibration, then you'd problaby want to look at a different tractor (unless you are looking for a project.)
New/Unused 20ft Farm Iron Gate (A48837)
New/Unused 20ft...
Gleaner R50 Combine (A50514)
Gleaner R50...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
2012 Ford F-250 4x4 Ext. Cab Pickup Truck (A50323)
2012 Ford F-250...
2013 Chevrolet Caprice (A50324)
2013 Chevrolet...
