Worn out band saw blades, good for anything?
   / Worn out band saw blades, good for anything? #21
Take a piece 5 "long and grind away the teeth, wrap 4" with electrician tape then you have a nice tool to scrape off old gaskets and dirt from the things you're working on.
I've made some that have come in handy
LOL, my handiest 'go to scraper' is made from a wide power saw blade.
   / Worn out band saw blades, good for anything? #22
Make lock picking tools. :)
Bruce
this is exactly what i was going to post..
the steel would be strong enough - would need to check the legality of it though..
Here in VA possession is a crime - but i really would like to take a lock picking class sometime
   / Worn out band saw blades, good for anything? #23
Hmmmm,,, does someone need a lesson on how to use YouTube?
I am sure you can find the instructions there,,,, everything ELSE is there,,,, :confused2:
Including how to make bump keys, which are even worse than picks.
   / Worn out band saw blades, good for anything? #25
Sorta off the wall ... but the porta band blades are just right as an internal hoop to hold the green purina 55# dog food bags open for trash etc.
2023 New Holland Workmaster 25S Compact Tractor - Only 65 Hours (A53472)
2023 New Holland...
2018 Ford F-150 Ext. Cab Pickup Truck (A51692)
2018 Ford F-150...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
1995 Rinker Captiva 190 (A53472)
1995 Rinker...
2022 New Holland Workmaster 40 Tractor with Loader (A51573)
2022 New Holland...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A53472)
2016 KBH...
