2 WIRE WELL PUMP PROBLEMS
   / 2 WIRE WELL PUMP PROBLEMS #1
Brimfield
Mass
Kubota L 3800
I have been having well issues for a week or so. I have the single phase 230 v 2 wire well pump. Last week it was not pumping when the switch came on for demand, pressure gauge was shot so I had no idea at what psi only way to tell was the switch kicking on and off but I had the full voltage going to the pump . The switch looked beat up so I replaced it along with a new gauge. The new switch is a 40 psi/60 psi and it worked like a charm for a week. Now again the pump is not kicking on when the switch calls for it, full voltage but it only draws 5.3 amps on either of the two legs. It normally ran around 6.5 amps running and never had a spike in amps. I ran an ohm test and the motor is fine, no grounding out. I checked the well tank pressure and that was ok. When the pump is working we have normal water pressure to shower run a washer and dishwasher at once. Is there any other checks I missed? The wires coming in to the hose look ok, no rodent chewed up wires.
   / 2 WIRE WELL PUMP PROBLEMS #3
If it is pulling 5.3 amps then the pump is running. If 6.4 amps are max then 5.3 amps means the flow from the pump is restricted. I think a dry well or pumping air would make the amps drop to 3.5 or so. My guess is a bad check valve. They tend to come loose and the poppet will stick, restricting the flow. This also happens if you screw the pipe in too far on the check valve. The pipe can actually hold the check valve closed.
I guess I need to pull the pump and check it out. My fear is that the start capacitor in the pump is bad. Right now it is working again, it's almost like it does not like running under a load or after heavy use . I can shut the breaker and wait 15 min. and then it runs. I will check the valve out when it's out. I know nothing about the pump, no paper work so I can only guess what size it is.
   / 2 WIRE WELL PUMP PROBLEMS #5
There probably isn't a start cap in that 2 wire motor. Most use a biac switch instead of a capacitor. When the water stops coming out is it still drawing 5.3 amps? If it is still drawing amps then the pump is still running, and you are just not getting any water for some reason. If the amps go to zero and the pressure switch points are still made, the overload in the motor is tripping. You don't have to turn the power off and back on to get the pump to start, the overload will automatically reset in a short period of time and the pump will start. But a tripping overload is not a good thing. It will only reset a few times. Then the motor will not come back on.
You said the pressure switch looked bad, which is a sign of the pump cycling too much. Once you have cycled the pump a certain number of times the overload starts tripping. Once the overload trips a few times the motor will no longer function, and you will need a new one. It is tripping after heavy use because every time it cycles on/off it is one step closer to death.
Well (no pun intended) the old switch was sticking with the contacts made at the end of it's life. I was worried that this might be a motor overload issue The pump still works, we try to go easy on it and space out water usage. I guess it is time to call our local Plumbing supply and price a pump. Not sure what we have for a pump. I even thought of getting a jet pump but I don't think that would save enough money to make it worth the trouble. Things hit when funds are low
   / 2 WIRE WELL PUMP PROBLEMS #7
I hear this all the time. Some people tell me they "just keep the faucet cracked open, letting out only a little water, so it doesn't hurt the pump". I guess that is just another one of those counter-intuitive things about pumps. Spreading out the water usage or just running the faucet partial open is the worst thing for pumps. You need to use enough water to keep the pump from cycling off, not just a small amount. Running just a partial of what the pump can produce is what causes the pump to cycle on and off. Cycling on and off is then what causes the points in the presure switch to arc out, and ultimately leads to the destruction of the pump/motor.
   / 2 WIRE WELL PUMP PROBLEMS #8
You can get a new honeywell switch on amazon for $ 17
paul
any takes on good well pump brands? looking at goulds, sta- rite and flotec to name a few.
   / 2 WIRE WELL PUMP PROBLEMS #10
When my start cap fried it didn't run at all. Pulled the cover and just saw the capacitor "sweating". Probably not the cap if it's starting.
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2019 KUBOTA SVL95-2S SKID STEER (A52705)
2019 KUBOTA...
2019 ALLMAND NIGHT-LIFE V SERIES LIGHT PLANT (A52706)
2019 ALLMAND...
2017 Nissan Frontier Pickup Truck (A53422)
2017 Nissan...
2015 Peterbilt 579 T/A Sleeper Cab Truck Tractor (A52377)
2015 Peterbilt 579...
Two Pairs of 8ft Fork Extensions (A53421)
Two Pairs of 8ft...
