2 WIRE WELL PUMP PROBLEMS
   / 2 WIRE WELL PUMP PROBLEMS #21
I've been using the CS pumps all year with no problems. I've only heard of a few cases where they have given problems. Cary have you personally seen any failures? I used to use the Goulds LS (Brass head) but they discontinued it in favor of the CS series. The GS is Goulds top of the line pump.
I have seen several cs pumps piled up behind my Goulds supply house. And I have heard from several installers that the crimped heads are coming loose.
Ended up putting in the Gould HS 10, a 1/2 hp 2wire 230 v 10 gpm pump. The old pump was a Monarch I think. We have sand and precipitated iron in our water so I have a whole house filter on the 1" line going in. The new pump rocks! I had no water pressure from the old pump if I ran a hose from the storage tank at wide open and it took time for the old pump to build up pressure. I back flushed the system with bleach running a hose from the tank back into the well, it was pumping over 35 with the tank valve wide open. I will post if I have any problems with the pump.
2019 Allmand Bros Maxi-Lite II 15kW S/A Towable Light Tower (A52377)
2019 Allmand Bros...
JOHN DEERE 5125R LOT NUMBER 24 (A53084)
JOHN DEERE 5125R...
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
2013 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A54313)
2013 FREIGHTLINER...
AUCTION STARTS HERE @ 9AM (A51406)
AUCTION STARTS...
