pneumatic seat pump dead - mahindra 8560
   / pneumatic seat pump dead - mahindra 8560 #1
dal929
I hit the button to add some air in the pneumatic seat and no sound from the pump. I can't seem to find anything on the seat/pump online, anyone have any info on troubleshooting this system?
thanks
Dal
   / pneumatic seat pump dead - mahindra 8560 #2
I was not aware the 8560 had a pneumatic seat.
hugs, Brandi
   / pneumatic seat pump dead - mahindra 8560 #3
Nothing exotic. Check your fuses, check the wires leading to the switch, check the switch connections and switch function.
A generic cause of this problem would be wiring damage in the area of the seat suspension scissors mechanism and an associated blown fuse.
Use a test light or VOM to troubleshoot circuits.
   / pneumatic seat pump dead - mahindra 8560 #4
If the compressor is bad there are lots of 12VDC compressors out there for not a lot of money. You don't need much pressure or volume for just a seat so you don't need to buy anything fancy. You could likely even find something in a junk yard. Lots of cars had small air compressors for this or that mostly suspension.
(2) UNUSED 7000# DROP AXLES W/ BRAKES (A51247)
(2) UNUSED 7000#...
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A53426)
2015 FREIGHTLINER...
2018 SkyJack SJ1056TH 4x4 Rough Terrain Telehandler (A52377)
2018 SkyJack...
PAIR OF DIAMOND PLATE DOUBLE AXLE FENDERS (A51247)
PAIR OF DIAMOND...
New Lewis Brothers MFG DB2 Poultry Housekeeper (A53472)
New Lewis Brothers...
UNUSED FUTURE 24" HYD TILTING BUCKET (A51248)
UNUSED FUTURE 24"...
