Best way to remove a broken zerk
   / Best way to remove a broken zerk #1
beowulf
Central California Foothills
Kubota L3410 HST, J Deere riding mower
I discovered that a zerk on the FEL is broken off flush. I thought about tapping a small flat head screwdriver straight in and trying to then get a bite so I could turn it out, but there does not seem to be anything there to bite on. I also thought about screwing in a self tapping screw and then trying to back that out. But, instead of all that I decided I would ask the question here as I am sure someone else has faced this issue.
Thanks in advance for any help.
   / Best way to remove a broken zerk #2
Probably the best way would be with a left hand spiral eazy out. If you don't have a set handy, perhaps one of the Torx bits would be the right size, if it wasn't seized in.
   / Best way to remove a broken zerk #3
Took the words right outta my mouth.
Thanks guys, will look into seeing what I have here and if nothing here, will get what you recommend.
   / Best way to remove a broken zerk #5
One of the few times when an EZ-Out will actually work in my experience.
   / Best way to remove a broken zerk #6
+1 on that. I've had many of the spiral type break trying to remove broken bolts. I switched to the square type for that.
   / Best way to remove a broken zerk #7
Left hand drill bit seems to work good for me.
   / Best way to remove a broken zerk #9
A cut nail is another option. They are tapered and hardened. ... If necessary, either grind the tip smaller, or grind some off to shorten until you get to the right size on the taper.
   / Best way to remove a broken zerk #10
ALL three of the first three options above, have worked for me...
SR
2013 VERMEER RTX1250 RIDE ON TRACTOR (A51242)
2013 VERMEER...
2020 CATERPILLAR 289D3 SKID STEER (A51242)
2020 CATERPILLAR...
2019 TAEKUCHI TL8 SKID STEER (A51242)
2019 TAEKUCHI TL8...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2020 VOLVO VNL760 SLEEPER (A51222)
2020 VOLVO VNL760...
Agco 8200 Flex Grain Platform (A50514)
Agco 8200 Flex...
