Canning qustions
   / Canning qustions #11
I have another problem. I was boiling a pot of water with the jars they had water up to the rim and two of the bottoms broke off why? It said you could boil to clean them up.
They probably had a flaw and just broke when they expanded as they warmed up.
Aaron Z
   / Canning qustions
Owell!. Now I have some new jars and the ball blue book
   / Canning qustions #13
Where the jars made for canning? You can't use an old mayo jar to can.
Also, don't have the jar sitting on the bottom of the pot with a rolling boil. Just boiling hot. My pressure cooker has a plate with a bunch of holes that sits on the bottom of the pot to keep the glass off the hot bottom. I do boil the jars and lids in a different pot but this pot has a bottom that is "crimped" for strength because the steel is so danged thin. This keeps the bottom of the pan a bit cooler since not all of the pan is in direct contact with the smooth top "burner."
Later,
Dan
   / Canning qustions #14
Some jars are made in china, and they break easier than Ball or Kerr jars, I will NOT buy them...
You do not have to cook the meat before canning it, (although I know there are some recipes for that) you can cold pack it as I said earlier. That recipe is in either my Ball book or the book that came with my All American canner, so I didn't make that up.
90 mins at 10# will get all the meat to the desired 250*, so there's no problem with that...
I wouldn't be afraid to use V8 but I have no idea how that would taste, I think I'd just add it to the meat after opening the jar, as the v8 comes already canned in the first place.
BTW, I'm still canning in jars I canned in with my mother when I was a kid.
SR
   / Canning qustions #15
Later,
Dan
I think freezing venison is much less work and probably retains more of the nutritional benedits. But besides that, water bath vs. pressure cooker I think you need to keep the jars off the bottom...my water bath pot (pickles and such) came with a rack. Never used a pressure cooker but I'm guessing the same concept holds. Ashamed to admit this but I made a blueberry pie once in a Pyrex pie pan...I can attest to the fact that you cannot warm up a pie (or anything else in a glass pan) on a cooktop unless your doctor says you need more glass in your diet.
   / Canning qustions #16
We mostly have Kerr since that is what the local stores carry for some reason. :confused3: But Ball is good too! :D
My impression is that the OP is only using a water bath and my quick read said to cook the meet before putting the lid on. Using a pressure cooker does not require precooking the meat.
The All American caner is a seriously good product. :thumbsup:
Later,
Dan
   / Canning qustions #17
Later,
Dan
I canned a lot of zucchini pickles this year and had a mix of new Ball and Kerr jars depending on what I could find (in a good year zucchini will throw off more than you can handle and trying to keep up with the jars can be a problem especially if the "peak" canning season has passed). Couldn't help but notice that the lids bore the same identical insignia (other than the Ball jars had a Ball name on them). I suspect they all come from the same factory.
   / Canning qustions #18
Jack, just to be clear, you DO have a pressure canner correct?. You can't do meat in a water bath canner.
   / Canning qustions #19
I AGREE, do NOT water bath meat!
Yes, folks "use to" do that, but that was before some of these super bugs came along, it's NO LONGER acceptable whether the meat is cooked or not!...
Water bath canning will NEVER get the food inside the jars above 212* or so, and that's NOT acceptable.
I have two All American canners and we love them both!
I can all year long,
we love our own canned beans with ham in them,
much better than what's available in the store and much cheaper too...
SR
   / Canning qustions
Yup it's a presto 16 qt. pressure canner.
2020 INTERNATIONAL LT625 (A52472)
2020 INTERNATIONAL...
2017 Challenger 607P-FS Vacuum Pump (A53117)
2017 Challenger...
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A52377)
2014 MultiQuip...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53473)
NEW HOLLAND 706 30...
2017 Mack GU713 Granite Tri-Axle Dump Truck (A51692)
2017 Mack GU713...
