Max 26XL - lack of power
   / Max 26XL - lack of power #11
the 1526/3016 machine is a heck of a nice product. You're going to love it.
You are correct, quite a stout little machine and a miniature version of my 5035. That 3rd range in the transmission really makes a difference in getting usable power to the ground. Had the opportunity last weekend to move and spread about 15 tons of asphalt millings and it performed flawlessly. Looking forward to trying out the 6ft snow pusher I have for it soon.
   / Max 26XL - lack of power #13
I initially thought mine was weak as well, but it turned out I was a newbie tractor operator. Sounds like your 26 had issues possibly. I have yet to stall it and I have moved some very large rocks and trees with the backhoe. Also a couple days ago I sunk the right front tire in a ditch moving 8 inches of snow. In 4 low in reverse on snow/ice I had all wheel spinning. Still stuck, I hit the dif-lock and it came out like it was on a flat surface. It just backed out like it was nothing. It was really sunk, when I do something I go all the way.
I did look at the 1526, and it was a tough choice. It came down to having to work in tight spaces, and being able to comfortably to trailer it.
Dan
   / Max 26XL - lack of power #14
Curious if any other Max 26 owners out there have found their tractors to be lacking power. Just purchased a Max 26XL Hydro with loader and am underwhelmed with it's power delivery to the ground. Specifically, in low range at max rpms, I have no trouble getting the tractor to stall out without spinning the tires while pushing/pulling a heavy load. This is on loose to moderately compacted dirt and will happen even in 2wd. Never had a tractor where the motor would give up before the tires would break traction in low gear. Very disappointed with this tractor's lack of guts compared to my old NH TC 24D and hoping there is a remedy. Fortunately, I have a well-established dealer with a top notch service manager who will do whatever is needed to make it right. Anyone else have a similar experience with one of these Max units?
Same problem but tractor was on flat and would not go forward until I put in low.
   / Max 26XL - lack of power #15
My max 26xl has never let me down. Always plenty of power. Itll spin the tires in 4wd with the diff lock engaged. I regulary carry two round bales at a time with no struggle. Only thing i hate about it is the hydrostatic pedals. Stiff and slow to return to a neutral position. Otherwise im very pleased with it. Mines a 2017 model.
Case Maxxum 140 (A50120)
Case Maxxum 140...
Super Star Smithco Bunker Rake (A50324)
Super Star Smithco...
2013 PETERBILT 367 HOT OIL UNIT (A53843)
2013 PETERBILT 367...
2012 VOLVO EC300DL EXCAVATOR (A51406)
2012 VOLVO EC300DL...
2025 SDLANCH SDLGC80 UNUSED Electric Golf Cart (A53117)
2025 SDLANCH...
