Kioti-KL130 loader 'C' bracket bent / power streering hose broken
   / Kioti-KL130 loader 'C' bracket bent / power streering hose broken #1
brainfog
Carlisle, MA
Kioti CK35 HST
I've bend the two 'C' brackets on the left side my KL-130 front end loader.
What is the actual name for the parts? Would anyone know the part number(s)?
Or alternatively - the location of the service manual for the loader?
On the right side of my CK35 HST tractor, a hose that operates the power steering sprays fluid when I turn the wheel.
In the service manual, I've found part number T2185-45032, is this correct?
Thank you,
Chris
   / Kioti-KL130 loader 'C' bracket bent / power streering hose broken #2
Thank you,
Chris
Do a search on MIE. Parts Finder Michigan Iron and Equipment Morrice, MI (855) 265-459
Do a search on MIE.
Thank you. Found it.
CK06-0200L (or R) Boom Linkage Assembly Outer LH
CK06-0100L (or L) Boom Linkage Assembly Inner LH
   / Kioti-KL130 loader 'C' bracket bent / power streering hose broken #4
Good deal.:thumbsup:
   / Kioti-KL130 loader 'C' bracket bent / power streering hose broken #5
Some call those "kidney links" due to their shape. On some tractors they are straight, not in a
C-shape, and cast steel, rather than mild plate with DOM welded in at the pivots.
Anyway, I have bent mine, too, so you are not alone. To repair, I cut nearly thru them at the bend, bent them
back in a press, then welded them.
I do not use the links at all when mounting my forks, just for the bucket.
If you buy a set of 4 new, I would be curious what they cost.
   / Kioti-KL130 loader 'C' bracket bent / power streering hose broken #6
I would also opt to press them back to original shape, then weld some plate the outsides so it doesn't happen again.
Tiger Mowers 80in Super Duty Twin Flail Mower Tractor Attachment (A55851)
Tiger Mowers 80in...
2018 John Deere 5075E MFWD Tractor (A53485)
2018 John Deere...
2012 Toyota Prius Hatchback (A55853)
2012 Toyota Prius...
GROUND PROTECTION PAD 8X4 15 COUNT (A55745)
GROUND PROTECTION...
2003 Big Tex 10PI...
