Put a dab of dielectric grease on the bottom of light bulbs.
   / Put a dab of dielectric grease on the bottom of light bulbs. #41
Yea tinned copper
So what product is the green/yellow grease you often find on OEM stuff the first time you change a bulb
   / Put a dab of dielectric grease on the bottom of light bulbs. #42
Re: Put a dab of dialectric grease on the bottom of light bulbs.
Doesn't that suck..... Why hasn't someone came up with some good, easy to use copper connectors?? :(
All of the automotive butt connectors I have are a plated copper alloy. They are not aluminum. I think the plating is likely cadmium.
I read thru some of the other posters in this same vein, and yes the plating is probably Tin and not cadmium. In any case I am not sure what the plating is, but the body of the crimp connector is copper, that much I am sure of.
   / Put a dab of dielectric grease on the bottom of light bulbs. #43
I don't think I've ever seen an aluminum butt connector. Prob cuz I never work with Aluminum wires. What electrical item are you working on, that has Aluminum wires? Incidentally if you are working with aluminum wire you MUST use aluminum connections, butt splices for example. Or if you MUST join your aluminum wires to copper, you have to use the proper goops for dissimilar metals. It's not ideal.
I'm assuming you misquoted in regards to never having saw an aluminum butt connector? What kind have you saw?
   / Put a dab of dielectric grease on the bottom of light bulbs. #44
James, where do you get copper connectors?
   / Put a dab of dielectric grease on the bottom of light bulbs. #45
Okay, I'm slow..... guessing my crimp connectors are also tinned copper.... sorry for the doubting.... thanks guys...
   / Put a dab of dielectric grease on the bottom of light bulbs. #46
Heating and breaker tripping of an induction motor under load is real, but the "poor connection" causing over heating of a resistance load is flawed.
That is not how it works. In fact, the poor connection acts as an additional resistance "heater" in series with the load.
E=I^2R Tells the entire story.
And then to make a short story longer......
The Great Lightbulb Conspiracy - IEEE Spectrum
I think we are saying the same thing but I don't think I said it very well. If there is a loose connection (poor connection caused by oxidation) it means that there can be poor electrical contact. This means that there is resistance to the electric current flow causing power to be dissipated as heat.
   / Put a dab of dielectric grease on the bottom of light bulbs. #47
Don't take our word for it, take off the plastic and take your pocket knife, and scrape it, and you will see the copper.
   / Put a dab of dielectric grease on the bottom of light bulbs. #48
How long will my "10 year" LED bulbs last if I do this? :D
   / Put a dab of dielectric grease on the bottom of light bulbs. #49
   / Put a dab of dielectric grease on the bottom of light bulbs. #50
I spray just a very little bit of WD-40 on the bulb threads of the first bulb to go in. After that they almost all screw in easily. How long they last? I doubt it makes any difference, but I always buy the long life bulbs anyway.
2017 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER TRUCK (A54607)
2017 INTERNATIONAL...
STORAGE FEES (A54607)
Unused 2025 LandHonor LDH-KN16 Mini Excavator (A52377)
Unused 2025...
JOHN DEERE 7300 LOT NUMBER 18 (A53084)
JOHN DEERE 7300...
2014 Ford F-150 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
2006 FORD F-250(INOPERABLE) (A53843)
2006 FORD...
