Remote Thermostat Control
   / Remote Thermostat Control #1
rekees4300
Elite Member
Indiana
JD4300
I have a 40'X80' metal shed, 150' from the house, that is heated by a thermostat controlled propane furnace. I want to be able to monitor the shed's temperature, and turn the furnace on/off from the house. How can that be accomplished?
   / Remote Thermostat Control #2
Get Nest thermostat (or a cheaper knockoff). You can control them with your smart phone, and it tells you how long the furnace runs for each day etc.
   / Remote Thermostat Control #3
If you have a router within the broadcast range of a wifi thermostat, you can do what Boyle mentioned. It might be better to steer clear of the Nest thermostat and get simpler one from Lowes or Home Depot
   / Remote Thermostat Control #4
I like the concept. I am wanting to put in a better and automatic heater in my detached shop/garage. Subscribed.
   / Remote Thermostat Control #5
We use sensi wifi tstats and control them with the wink mobile app. I also have them for my business and control all with the single app. Lots of neat features with the wink app as well.
I don't have a cell phone but do have a wifi router with 650' range. However, my concern with a wifi thermostat is that it wouldn't have enough signal strength to penetrate the shed's metal (steel) walls, 150 feet open air, plus 2 wooden house walls?
   / Remote Thermostat Control #8
Take a laptop or take your phone and turn off data and see if you can connect from the shed. If you can connect and get online, you are good to go. If not, you will need to run a cat 5 cable from the house to the shed. I think your existing wireless should be able to go the distance.
Okay thanks, I'll do some experimenting and see what happens.
   / Remote Thermostat Control #10
I have a Honeywell WiFi thermostat that has an app for smart phones. It works well, but as others have said, it needs a WiFi connection.
2013 East Manufacturing 45ft T/A Walking Floor Trailer (A53422)
2013 East...
2023 ACE SC804050L SANDBOX TRAILER (A54607)
2023 ACE SC804050L...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A54313)
2016 FREIGHTLINER...
2008 AAR MOBILITY SYSTEMS REFRIGERATED CONTAINER (A54607)
2008 AAR MOBILITY...
JOHN DEERE 437E KNUCKLE BOOM LOADER (A52705)
JOHN DEERE 437E...
Sterling 9500 (A55301)
