Series 4 PTO shaft, how short can I go?
   / Series 4 PTO shaft, how short can I go? #1
Supercharged86
Cranston, Rhode Island
Ford 335
Hello Everyone, I was hoping someone can tell me what the "Absolute" shortest (say end-end including yokes and joints) I can cut down a series 4 PTO shaft with 1-3/8" 6 spline on either end? I'm trying to build a homemade log winch using a vintage Ramsey #200R 8000lb winch that will be mounted fairly close behind the 3 pt arms (design version #1). Thanks in advance. Steve
   / Series 4 PTO shaft, how short can I go? #2
I've seen them with less than a foot of tube. But the hitch range of motion gets involved quickly as well as joint angle.
   / Series 4 PTO shaft, how short can I go? #3
I agree that the arm movement needs to be limited. The three point has the lift to mangle.
Hi Guys, Thanks. Right now I'm looking at a length of 22" between shaft ends (PTO-Winch). I'm not sure how long the typical yoke and joint ends are but will this work? Any thoughts on length of travel at this measurement? Thanks. Steve
   / Series 4 PTO shaft, how short can I go? #5
I don't see a problem with the 22" length as long as you can keep it close to straight or aligned when operating. Most of the stress and wear is when the joints are not straight as possible.
   / Series 4 PTO shaft, how short can I go? #6
Also be sure to maintain proper overlap of the shaft profiles through the hitch range of motion.
Thanks Guys and Happy Thanksgiving. This is my first PTO shaft, is there a rule of thumb on the required overlap. Steve
   / Series 4 PTO shaft, how short can I go? #10
This big issues are overlap, which has been well addressed, and u joint angle.
This chart describes how quickly the life of the joint is shortened by increasing the angle the joint operates at.
Increasing the angle also causes the shaft to not operate smoothly inducing vibration.
Unlike the constant velocity joints used on all front wheel drive cars and now many all wheel drive ones as well, the rotational angles of the cardan style joints are not uniform throughout 360 degrees.
Yes if you turn one end of the shaft a full turn the other end will also turn a full turn but in between the full 360 degrees the amount of rotation is not always the same at each end. If you take a socket universal joint and try and turn a nut while the joint is at a strong angle you will feel the lumpy action I am referring to.
This link is to a government web site explaining to farmers the limitations of cardan joints
http://www1.agric.gov.ab.ca/$department/deptdocs.nsf/all/eng9924
Dave M7040
Sorry but I dont know why the link is not a link but you can copy and paste into your browser to read it
Eager Beaver (A50322)
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A52128)
Kubota 24in Quick...
John Deere 4020 Tractor (A50514)
John Deere 4020...
TRUCKING INFO (A50775)
New Power Line 500 Metal 3pt. Spin Spreader (A50774)
New Power Line 500...
Pallet Of Mini Excavator Attachments (A47384)
Pallet Of Mini...
