nx6010 transmission fluid spec?
   / nx6010 transmission fluid spec? #1
HK45
Gold Member
Bethlehem, Pa
Kioti nx6010 loader backhoe
I have a NX6010 Cab model. Why does the owners manuel say 11.9 gallon for the transmission fluid and replacing transmission fluid and filter it says 14.6 gallons. Which is the right one?
   / nx6010 transmission fluid spec? #2
I would call the dealer and find out. If you are still unclear, measure the amount coming out. Also refill with 11.9, then check it. It is easier to add than take away.
   / nx6010 transmission fluid spec? #3
Beats me which is right. Fill until on the dip stick. Start engine. Let run for awhile. Cycle power steering, cycle three point, cycle loader. Shut engine off. Check dipstick fill to the lower to middle band on dipstick as the fluid will expand when warmed up.
   / nx6010 transmission fluid spec? #4
I believe the the 11.9 is for a gear model and the 14.6 is a hydro model.
2023 Chevrolet Tahoe FL SUV (A55853)
2023 Chevrolet...
Hose Reel (A55758)
Hose Reel (A55758)
1980 Gleaner F2 with heads (A55302)
1980 Gleaner F2...
2023 PETERBILT 567 VOLUMETRIC CONCRETE TRUCK (A55745)
2023 PETERBILT 567...
Kubota ZD326 60in Zero Turn Mower (A55851)
Kubota ZD326 60in...
2005 Dodge Caravan Van (A54815)
2005 Dodge Caravan...
