   / Harbor Freight Tools that don't suck #6,561
So has anybody hade any experience with these types of HF storage bins. I see there are a few different ones. Even though the Milwaukee storage box is reduced in price now these are still 50% cheaper even without a coupon. I have like 2 dozen loose boxes of assorted sizes of different screws and nails from past projects but the boxes are all falling apart now.
8 Bin Portable Parts Storage Case
I have several of these exact items that I use to store nuts, bolts, lag screws, etc. They are OK. Don't plan on carting stuff around in the back of your truck in them, or carrying them around like a suitcase; They are too flimsy for that. But using them to store stuff and leaving them on a shelf when not in use, they are just fine.
One thing I did to improve them is to use a hot glue gun (Harbor Freight) to glue the dividers in place. Otherwise the dividers slide up and your parts get mixed up. It adds a bit of rigidity to them too.
   / Harbor Freight Tools that don't suck #6,562
I keep my leftover wood screws in the lure sections of an old fishing tackle box, the type with fold-out trays and the two halves of the lid met at the top. Another useful yard-sale find.
   / Harbor Freight Tools that don't suck #6,563
I have similar ones I got at HF. In theory, they are great and I use them for all sorts of small parts. Unfortunately, the latches broke on some of them and it sort of renders them useless. I also have some from Lowe's or Home Depot that look about the same and the latches have not broken. I would skip HF and buy somewhere else that will take them back if they broke. They cost about the same at both places.
   / Harbor Freight Tools that don't suck #6,564
Has anyone purchased and used the 1/2" air impact (1000lb/tq)? I would like a bit more power than I currently have, pretty light use, but want it to work when needed. Does it really have that much torque? I just got a flyer from HF that has it on sale for $129 (normally $149). I know this has come up previously, but I had not seen where someone had used it and liked it..
   / Harbor Freight Tools that don't suck #6,565
I have the Earthquake 1/2" impact (IIRC, it was on sale for $80ish?) and have been very happy with it.
Aaron Z
   / Harbor Freight Tools that don't suck #6,566
There was quite a bit of discussion earlier in this thread about the Earthquake impact wrenches but I don't recall it that was the air operated or the electric ones.
There's a search thread option at the top of the page. If you search earthquake you should find them.
   / Harbor Freight Tools that don't suck #6,567
Lots has been written about the regular 1/2" (air) Earthquake that sells in the $80 range. General thinking is that it is top notch, super duty and puts out the 700 ft lb of torque claimed. I have one and will vouch for it. I can take anything off and put anything back on. No exceptions so far and I try pretty hard.
   / Harbor Freight Tools that don't suck #6,568
Aaron Z
Ditto on the Earthquake.
Its intermediate setting torqued my tractor lugnuts to where 150 ft lbs on a beam-type torque wrench couldn't tighten them more, or loosen them.
I don't think I have an application that would use the highest setting, or could resist loosening with this thing.
And a comment: This Earthquake uses far less air than the the two cheaper HF models I shouldn't have bought earlier. Both used so much air that they caused the "2.5 hp" :) HF compressor to kick in after a few lugnuts, and then they became weaker as they exhausted its tank. The Earthquake uses far less air, generally the compressor won't kick in at all. I think it would be usable with a little pancake compressor if that's all I had.
I had an HF electric impact wrench, it couldn't remove old automotive lugnuts. Sold it at a yard sale.
   / Harbor Freight Tools that don't suck #6,569
I don't know if its been mentioned but the DIESEL COMPRESSION TESTER, IS GOOD..
I have the "master" kit.
I recommend it for Case, J.Deere and Ford tractors. It comes w/ glow plug adaptors AND injector adaptors, along w/ a guage.
It makes SHORT WORK out of engine diagnosis..
Weather its helping out a friend or making a few bucks on the side.. its more than paid for itself..
   / Harbor Freight Tools that don't suck #6,570
Plus another one on the Earthquake 1/2" air gun. Works well and really good value. I too have never used the high setting.
2015 DRAGON 130 BBL STEEL VACUUM TRAILER (A58214)
2015 DRAGON 130...
2004 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A55745)
2004 INTERNATIONAL...
2014 Ford Taurus Sedan (A56859)
2014 Ford Taurus...
2017 Chevrolet Tahoe SUV (A56859)
2017 Chevrolet...
2015 Ford F-550 Crew Cab Godwin 184U Mason Dump Truck (A56858)
2015 Ford F-550...
2019 Caterpillar 249D Compact Track Loader Skid Steer (A55973)
2019 Caterpillar...
