Starting my generator this winter shud be easier
   / Starting my generator this winter shud be easier
I use starting fluid for testing engines for spark or no spark and have been lucky so far . I did stretch the valve covers on a Rocket 350 years ago, they were square then a bang and they were round and almost pulled the bolts through, as long as you know a little goes a long ways it is good stuff. Your workman ship is top notch,well planned and your video was filmed well and I enjoyed it. My generator goes half a year to a year between starts and I had to go propane to get away from my fuel going stale . My electricity goes out during the high winds and they cant fix it until it dies down to go up in the bucket trucks so can be a few days and takes more gas then I would want to store even with stabil in it. Mine always smoked and stank when I got it started and sometimes had to run half choke the whole time.
Wind is the problem here too. In recent years we haven't had many failures but when they happen I have to get the generator going for the fridges and freezer. Thanks for the comments re my workmanship and videos.
Interestingly enough, at least in Eastern Kansas, my generator has always started on the first pull with just stabilized non ethanol gasoline in it. I bought it at Sams Club on sale for $199.00. I think the engine is a Honda Clone. I also have a Honda Push mower. always starts on the first pull. My Cub Cadet snow blower is a little finicky though, but it has electric start so isn't really a big deal. I always use non ethanol fuel for storage over the winter months with either Stabil in the fuel or SeaFoam
I use a fuel stabilizer with the Motormaster brand. Can't say that I have been entirely faithful with amounts and procedure over the years though. My Honda lawn mower starts first time every time. The $100 6.5 hp engine on my homemade soil screener has been giving starting trouble lately so I will probably try to adapt the feeder tube idea (as in the video) to that engine next spring.
   / Starting my generator this winter shud be easier #23
SeaFoam can work wonders on these small engines to keep them clean and running strong. Crappy gasoline is their worst enemy.
   / Starting my generator this winter shud be easier #24
Todays non ethanol gasoline is much superior to any gasoline sold from the 1910's to thr 1980's.
   / Starting my generator this winter shud be easier #26
OP: If this works, kudos to you! I have a very similar generator labeled ETQ, and it's also difficult to start by just choking and pulling. I had to really rip on the cord, and actually broke it once. I discovered that if I held the throttle at idle, it would fire right off and idle nicely!
I think the reason it doesn't want to start normally is because the governor is holding the throttle wide open, trying to get the RPM's up, even while I'm pulling the rope...
I made a catch for the linkage that holds the throttle down close to idle speed. I hook it, choke it, and pull the rope and it's idling on the first pull now. After it idles for a bit, I release the linkage and let it rev up. Obviously it's not going to power anything at idle, so I leave the breaker off until it's at governed speed so I don't damage anything that might be plugged in. Probably a lot easier on the motor than having it immediately head for 3600rpm's when it's really cold out...
Two other things I did that help... First, I ALWAYS turn the fuel off and run the carb dry before I shut it down, using the choke more and more as it starts to sputter, until it finally quits. That keeps the carb from gunking up due to the ethanol combining with water from the air. Even non-eth gas sitting in the carb seems to lose it's volatility over time, so this way it's getting fresh gas from the tank. Second, I put synthetic oil in mine, and that made it noticeably easier to pull below freezing. I just used Rotella T6 15W40, as that's what I had laying around. If I used it more in the winter, I'd probably do 5W30 or 0W20 instead. A fridges and freezers aren't much load, unless you've got a LOT of them, so it's probably going to run cool anyway...
And to those of you saying "that wasn't necessary, my generator starts fine", I say that's great, but his isn't yours. I'm happy for you, but your point is pretty moot.
He's in Newfoundland, and uses it mostly in the winter... If your generator starts easily with one pull at -40F, I'll eat your sock. :)
I wouldn't worry about unfiltered air getting in either... It's winter... Not usually much dust. You could run it with no filter and it'd probably never have an issue...
   / Starting my generator this winter shud be easier #27
What do you base your opinion on?
It's all about the additives they use. Top Tier rated gas is your best bet and the additives have gotten a lot better over the years. Basically all unleaded gas is the same, it's the additives each company uses is what sets them apart.
   / Starting my generator this winter shud be easier #28
I think the reason it doesn't want to start normally is because the governor is holding the throttle wide open, trying to get the RPM's up, even while I'm pulling the rope... I made a catch for the linkage that holds the throttle down close to idle speed. I hook it, choke it, and pull the rope and it's idling on the first pull now. After it idles for a bit, I release the linkage and let it rev up. Obviously it's not going to power anything at idle, so I leave the breaker off until it's at governed speed so I don't damage anything that might be plugged in. Probably a lot easier on the motor than having it immediately head for 3600rpm's when it's really cold out...
I also put synthetic oil in mine, and that made it noticeably easier to pull below freezing. I just used Rotella T6 15W40, as that's what I had laying around. If I used it more in the winter, I'd probably do 5W30 instead.
He's also in Newfoundland, and uses it mostly in the winter... If you didn't know, it gets really cold there, and everything starts hard in the cold, if only because it's harder to pull over quickly.
Walk behind snow blowers do not have a air filter element because they would just plug solid with the blowing snow in the air.
   / Starting my generator this winter shud be easier #29
That made me laugh. Should we all remove the air filter off our vehicles when driving in a snow storm behind an 18 wheeler? I think not!
The one thing I have learned from reading all these post is don't buy an engine that has Champion or Tecumseh on it.
   / Starting my generator this winter shud be easier #30
That opening is for air intake and the air has to go through (what looks like) a pretty dense filter to get to the carburetor, so hard to see how the starter fluid spray would find an easy way through the filter - but I don't know what would happen for sure.
I've sprayed ether in tractors with oil bath breathers on them and they will crank. The suction from the engine will suck the ether in regardless of air filter etc.
   / Starting my generator this winter shud be easier #31
I think you are doing more then spraying tractors with that ether if you are driving your generator behind a 18 wheeler, try to focus on generators and not looking for a fight, you are not making yourself look smart by trying to make us look stupid .
   / Starting my generator this winter shud be easier #32
I find it hard to believe there is an engine of any sort out there without an air filter on it is what I am saying, never mentioned anyone being stupid, you said that. Where did I say I was driving my generator behind an 18 wheeler? You tell me to focus on generators and your talking about snow blowers.
I've only ever owned one walk behind snow blower and it did have an air filter. If they don't now then that is my mistake and sorry if I offended you or anyone else. To me if they don't have an air filter then they are just sucking snow in the intake and we know what snow turns into when melted and that can't be good for an engine. Just my thought on it.
   / Starting my generator this winter shud be easier #33
I've had 3 snow blowers. Two 5 HP and one 8HP, no air filter elements on any of them, just a metal shroud.
   / Starting my generator this winter shud be easier #34
Snowmobiles also don't have "filters" of any sort. Or none that I've owned anyway. Best case, they have a large mesh screen to keep the mice out, but my mountain sleds don't even have any sort of foam. Again, it's winter... Not much dust to worry about. No bugs, not that they'd hurt anything... And a little blowing snow goes right on through without hurting anything. It's just "humidity" to an engine. :)
   / Starting my generator this winter shud be easier #35
I learned something new today. I apologize for my ignorance.
   / Starting my generator this winter shud be easier #37
I find it hard to believe there is an engine of any sort out there without an air filter on it is what I am saying, never mentioned anyone being stupid, you said that. Where did I say I was driving my generator behind an 18 wheeler? You tell me to focus on generators and your talking about snow blowers. I've only ever owned one walk behind snow blower and it did have an air filter. If they don't now then that is my mistake and sorry if I offended you or anyone else. To me if they don't have an air filter then they are just sucking snow in the intake and we know what snow turns into when melted and that can't be good for an engine. Just my thought on it.
I worked on a Honda outboard motor without an air filter. I guess they figured there wasn't much dust on the water.
   / Starting my generator this winter shud be easier #38
My mountain sled draws the air from behind the windshield, through a piece of foam...that keeps the snow out...
SR
   / Starting my generator this winter shud be easier #39
I like the name change! Null. Why didn't I think of that?
I already said I learned something new and I apologize for my ignorance. We don't have much snow here. Never been on a snowmobile. Only had one snow blower and it had an air filter. I have a boat, it's a 14' Jon boat and it has no engine. It does have a motor, trolling motor. I haven't worked on a boat engine, didn't think about them not having an air filter. I just assumed every engine had one since every engine I've ever worked on had one. I was wrong. I admit it. Engines run on some sort of fuel, motors run on electricity. Put that in your coffee this morning and ponder on it.
   / Starting my generator this winter shud be easier #40
SR
Any sleds I've had since the early 90's had a similar setup.
Some of the my older 70-80's sleds may have been open carbs
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
WHISPERWATT 220 DIESEL POWERED GENERATOR (A58214)
WHISPERWATT 220...
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
2022 KAUFMAN 2 CAR TILT GOOSENECK TRAILER (A59905)
2022 KAUFMAN 2 CAR...
2002 Ford Thunderbird Convertible (A59231)
2002 Ford...
