Broken drawbar... chances a 'pro' welder can fix it
   / Broken drawbar... chances a 'pro' welder can fix it #131
But in the chaos there's some really good info. :)
   / Broken drawbar... chances a 'pro' welder can fix it #132
This drawbar may be like Humpty Dumpty, all the Kings Horses and all the Kings men, cant put that drawbar back together again. I suspect the OP already has this fixed, but the conversations sure are interesting.
   / Broken drawbar... chances a 'pro' welder can fix it #133
btw, am I the only one who suspects that the hole surrounding the break is a 'safety' feature to spare breaking the housing? :confused: Swinging drawbars I recall have a pin that drops alongside the bar, not thru it ....
Non-swinging drawbars often have multiple holes to let you choose how far out the drawbar is set to (so you can set how far back your towed load pivots and to make the PTO shaft ujoints happy.
Aaron Z
   / Broken drawbar... chances a 'pro' welder can fix it #134
Aaron Z
:thumbsup::thumbsup:
   / Broken drawbar... chances a 'pro' welder can fix it #135
Aaron Z
And there are additional holes, more in the middle of the drawbar, for things such as trailer safety chains, Hammer Strap hitches, etc. I think one of those is where it broke.
   / Broken drawbar... chances a 'pro' welder can fix it #136
Is anyone else curious what the OP did to fix or replace his drawbar? I am. He did not send it to me with $50 to have me weld it for him, that much I can say.
   / Broken drawbar... chances a 'pro' welder can fix it #137
Man that was 8 days ago. We have covered welding, glass bendage and came up with a welder to weld all welds. Where you been?
   / Broken drawbar... chances a 'pro' welder can fix it #138
Reckon I slept thru some of it...:ashamed:
   / Broken drawbar... chances a 'pro' welder can fix it #139
After a few days a thread develops a life of it's own. The OP then realizes nothing he can post will be relevant since the subject has moved farrrrr from the original issue. So you get crickets. :)
   / Broken drawbar... chances a 'pro' welder can fix it #140
Yeah, we have talked this one to death.:shocked:
2004 TerraGator 8104 (A53473)
2004 TerraGator...
Paint Dryer, Briggs 5.5 (A52384)
Paint Dryer...
Echo Weedeater, Stihl Pole Saw & Predator Gas Auger (A50123)
Echo Weedeater...
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
2017 Peterbilt 567 Day Cab (A52384)
2017 Peterbilt 567...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A51692)
2006 iDrive...
