Broken drawbar... chances a 'pro' welder can fix it
   / Broken drawbar... chances a 'pro' welder can fix it #121
Are you agreeing with me or not??? I sortta lost track in there somewhere. :)
It is OK, Richard, I got it. I will fill you in later...
By the way the second installment about the Corning Glass was pretty interesting I thought.
   / Broken drawbar... chances a 'pro' welder can fix it #122
Richard, lets try this. You know that if you bend a piece of steel bar it can be bent past the point of just bending, it can bend to the point of staying bent.
If you bend glass, it can bend, but it will always spring back to its original shape, AND you cannot bend it past the point of bending and have it stay bent. At least not without heating it. If you try to bend the glass beyond the point of bending, it fails catastrophically. Obviously some glass can bend way more than others. Did that help any, or just muddy the waters.
   / Broken drawbar... chances a 'pro' welder can fix it #123
New title "broken glass drawbar" chances a 'pro' glass person can fix this? Hahahaha
   / Broken drawbar... chances a 'pro' welder can fix it #124
Now that we have all been introduced to Prince Rupert drops.. Take a look at what it takes to bust the head of one of these things:
   / Broken drawbar... chances a 'pro' welder can fix it #125
I guess if he can't find a welder maybe a glass shop can make him a new drawbar. :)
Bruce
   / Broken drawbar... chances a 'pro' welder can fix it #126
Bruce
well, it is going to have to be one of those newfangled tempered ones.:)
   / Broken drawbar... chances a 'pro' welder can fix it #127
You Know, It really does not matter a ratzazz if the bar was "hardened" originally or not.
   / Broken drawbar... chances a 'pro' welder can fix it #128
Bruce
He may have difficulty being able to tell where the hole for the hitch pin is.
   / Broken drawbar... chances a 'pro' welder can fix it #129
... and what James said. Wasn't it in a thread about steel vs wood beams over a three car garage??? IIRC, it was discussed that hardness only affects the amount of elastic deformation before plastic deformation or breakage occurs.
I thought for several pages that 4140 PHT would be my choice to DIY a new bar. :eek: (Common for AR barrels, transmission shafts, hardenable) Don't recall the OP's dimensions, so I guessed when shopping. 1 1/4" x 2/1/2" x 24" 4140, around $1.60-some/inch, so ~$40 and a fetch or ship if the size is close.
btw, am I the only one who suspects that the hole surrounding the break is a 'safety' feature to spare breaking the housing? :confused: Swinging drawbars I recall have a pin that drops alongside the bar, not thru it ....
(I claim old age and a high blood/steel content. :laughing:)
   / Broken drawbar... chances a 'pro' welder can fix it #130
Ha, ha Richard... I am not disagreeing with you... yes, glass can bend before it breaks. Very evident if your aspect ratio is relatively high (height/width) which drives stiffness and your beam length is long enough to observe. I guess I am feeling sorry about now for the OP. He just wanted to fix his dang drawbar. :laughing: Some of us love to learn regardless of the tangent the subject/thread might take and enjoy the extraneous discussion. :drink:
2019 Ram 1500 Classic 4x4 Crew Cab Pickup Truck (A51692)
2019 Ram 1500...
2004 GMC Envoy SUV (A51694)
2004 GMC Envoy SUV...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
1998 Talbert TDW-35S-HRG-1-T1 Detach, GVWR 84,300 (A52384)
1998 Talbert...
2016 Big Tex 14LX 14ft 7 Ton T/A Dump Trailer (A50322)
2016 Big Tex 14LX...
2006 Ford F-350 Forestry Dump Truck (A51691)
2006 Ford F-350...
