Oil & Fuel fuel is flowing backwards from fuel filter head
   / fuel is flowing backwards from fuel filter head #2
More information please..
how do you know this??
was the engine running like this before you noticed it??
If you had the lines off and NOW its running backwards.. swap the lines..
   / fuel is flowing backwards from fuel filter head #3
fuel ls flowing wrong way out of fuel filter
It surely does not do that for long does it?
Would you have the fuel tank outlet confused with the return line?
More information might help.
there is no fuel flowing from the filter to inj. pump except through the bleed back line from front of pump back to filter that line lets a little fuel past the check valve back to the pump. all original lines only go on one way. I really want to thank every one who is trylng to help me.maybe it is the filter head
   / fuel is flowing backwards from fuel filter head #5
There are arrows on the filter head for flow direction..
Is your filter a 3 piece?? head, filter, & bottom bowl..
You put the oring ON THE FILTER didn't you?? take it back down and put the oring UP IN the filter head.. problem solved..
2019 Autocar ACX Xpeditor T/A EZ-Pack Front Loader Garbage Truck (A55852)
2019 Autocar ACX...
18" PIN ON BUCKET (A52707)
18" PIN ON BUCKET...
Kubota RTV900 4x4 Utility Cart (A55851)
Kubota RTV900 4x4...
2012 INTERNATIONAL PROSTAR+ (A55745)
2012 INTERNATIONAL...
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A51691)
1996 JLG Commander...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
