Ramps for loading tractor on truck bed
   / Ramps for loading tractor on truck bed #1
Bikewanderer
Gold Member
I am looking for some advice here. I have a f350 dually with 12' flatbed. I would like to be able to move my tractor occasionally, but do not want to own a trailer. I have enough load capacity and room on the truck bed that I have little use for a trailer except for this. The tractor is a l3400 kubota. The truck weighs 7000# empty and has a 13000# gvwr.
My buddy pointed me towards some pin on ramps, they look pretty safe. Pricey, but I definitely want to be safe. Looks like it will run close to $1500 to get them shipped and installed on my truck bed. Does anybody move tractors this way that can offer any advice?
   / Ramps for loading tractor on truck bed #2
Find a welding shop nearby and have them quote you some, $1,500 sounds high to me.
   / Ramps for loading tractor on truck bed #3
I don't know how you could fit an L3400 on a 12ft.bed.NO FEL?maybe.
I though about that, not sure I'd be able to pick them up in steel!
It's about 12' long. Could put the bucket up on the headache rack or hang Off the back a little.
   / Ramps for loading tractor on truck bed #6
No way you are going to get a 12' tractor with a FEL on that size bed safely. You need some angle to the chains to secure properly.
For the money you are going to spend you could put $500 more towards it and have a trailer that's good for a million uses vs a set of ramps that are good for one.
To boot the ramps will have no resale. All three trailers I have owned i have sold for more 10 years down the road.
Chris
   / Ramps for loading tractor on truck bed #7
LOL, when I had my 3/4 HD GMC pu I used to load my MT180D in the PU box.
Was, however, kinda 'top heavy'.
Still have the home made ramps and I now use them with my 5 X 10 dully trailer.
What I have seen was using the FEL to 'latch onto' a truck bed and the front wheels raised off of the ground thus towing a tractor on its rear wheels sort of a la trailer, maybe OK if suitable chains and lights were used but I sure would not want to go far.
Bit off topic, but I used to tow my ATV behind my CUT when working a fair distance away as the CUT only had a ground speed of about 6MPH and going home for lunch took longer than eating it.
I think at this point that owning a trailer is out of the question. I am unwilling to devote the time and money to property taxes, insurance, and maintenance on one more set of wheels. If necessary, I guess I would rent a trailer when I need it, or would be willing to transport it without the front end loader. at the current moment, I have no need to transport it whatsoever. I do transport my John Deere 455 riding mower in this way and it works quite well. I just don't want to be in a position where someday I will need to take it to the dealer for repairs or do some box blading at a rental property and will not have the ability to move it. It did occur to me after posting that I do have a 5 x 8 high side equipment trailer with a 5000 pound axle on it. This might be able to move the tractor if I can put the front end loader down on the tongue.
I'm sure some of you can relate. I am coming out of a period of time where I just bought too much stuff. Anything that I only used a couple times a year I am selling and will be renting in the future. The stuff I do use I am repairing or replacing such that it is in very good condition.
   / Ramps for loading tractor on truck bed #9
I am also in the trailer camp and have two. Trailer rental, as you mention, would be a viable option if seldom used. Around my area a trailer of the type I would need for my larger tractor is a hard rental to find, as the rental yards use them for their equipment rental. I think your bed is too short to properly chain the tractor down and have a safe ride, which is the reason I recently upgraded a 10' utility trailer to 16' length to carry a new UTV. I would also think your rig will be top heavy. YMMV.
   / Ramps for loading tractor on truck bed #10
Trying to get a JD X740 garden tractor onto a high trailer which is about the same height as a 4x4 truck using ramps is scary. Slip off there is nothing to do but lay down and die under the thing. I stopped transporting my garden tractor because of that. But I have a monster gooseneck trailer for an emergency. No ramps for me.
207280 (A52708)
207280 (A52708)
2014 INTERNATIONAL PROSTAR (A58214)
2014 INTERNATIONAL...
1701 (A58375)
1701 (A58375)
2000 INTERNATIONAL 9200 (A58214)
2000 INTERNATIONAL...
FUEL PUMP W/ ELECTRIC METER, HOSE & NOZZLE (A52708)
FUEL PUMP W/...
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
