Running Well Water Line in 2" Conduit
   / Running Well Water Line in 2" Conduit #1
Pettrix
High Desert Southwest
I want to run 1.25" PEX, along with my power wire, from the garage to the well area and enclose it within a 2" conduit.
Will this be difficult to run inside the 2" pipe since PEX tends to want to curl upon itself?
Any tips?
   / Running Well Water Line in 2" Conduit #2
Yes - there must be some reason that you want to make this so difficult. Run the 1.25" PEX plus the power in 4" heavy wall plastic pipe. Makes the job so much easier and if you have to repair either - you will be able to pull either or both back thru the 4" pipe without having to dig it all up.
This is how I have my water & power running from the house to my spring - 145 foot run.
   / Running Well Water Line in 2" Conduit #3
4" pvc pipe would be pretty pricey but if you have the funds, a good way to go. Bob
   / Running Well Water Line in 2" Conduit #5
My brothers underground boiler lines and wires run through that black, un-perforated corrugated flex pipe, works well and is reasonable.
   / Running Well Water Line in 2" Conduit #6
I cant imagine that lasting very long if it is buried. I'm sure it will collapse in the not so far future. I have seen schedule 80 PVC pipe collapse. If it's going in the ground use schedule 40.
   / Running Well Water Line in 2" Conduit #7
Just so you know. Schedule 80 is much more durable than schedule 40. For cost reasons he should be OK with sch40 for what he's doing unless he is burying it under a freeway.
   / Running Well Water Line in 2" Conduit #8
Yep, I realize that. I was just saying I have seen schedule 80 collapse.
   / Running Well Water Line in 2" Conduit #9
Any tips?
This violates just about every code out there for the simple reason water conducts electricity. Do not do this.
You need to dig two trenches and run power and water in separate tranches. There is even a distance apart from each other that they need to be, but I forget what that is off hand. Two feet apart is probably good.
It is also a bad idea to run a water line inside a bigger pipe because of the movement of the water carrying pipe inside the conduit. This will lead to early failure.
Some times it's OK to save a buck, but for utilities buried in the ground, spend what it takes to do it the best way possible.
   / Running Well Water Line in 2" Conduit #13
Run a 2" conduit down each side of a 2' ditch & you can pull the pipe and wire through them. Conduit for a wire could be beneficial but i would just bury the water line ( 1" pex is adequate ) .
Out here they do that ALL the time and code officials are perfectly OK with it. They actually allow you to drop PEX and the power wire directly into a trench, no conduit, sitting on top of each other.
Why is it dangerous?
If you think about it, the well pump wire is sitting inside a well with a 100+ feet of water surrounding it.
The movement of the PEX is almost non-existant. PEX sits inside floor slabs and inside walls, near live power wires. No code violations.
   / Running Well Water Line in 2" Conduit #15
This. Dig it once, but run them separately. You'll be glad you did.
   / Running Well Water Line in 2" Conduit #16
I don't think you would ever get that pulled in.
I have given up on the 4" Big O. It just doesn't last. Last job I did here, I used 3" thin wall super duct that comes in ten foot sections. Went around five hundred feet for some lighting.
I'm curious what the reason for the conduit is. Protection or some notion of easy future replacement?
   / Running Well Water Line in 2" Conduit #17
Why is that?
Recommending sch 40 because you had seen sch 80 break. That makes no sense. "The heavy duty stuff broke so here try this light duty stuff"
   / Running Well Water Line in 2" Conduit #18
Made sense to me. He was comparing to black plastic flex pipe and saying that sch 40 would be better, but he's even seen sch 80 break. Reread the series of posts and it will make sense to you.
   / Running Well Water Line in 2" Conduit #19
You obviously didn't understand my post or I wasn't clear. All I said was I have seen schedule 80 collapse and I recommended to him schedule 40. But what ever. :confused:
   / Running Well Water Line in 2" Conduit #20
Thank you, I thought I was in the twilight zone there for a minute
2014 Aerway Aerator (A55973)
2014 Aerway...
2015 Ford Focus Hatchback (A59231)
2015 Ford Focus...
UNUSED FUTURE 40" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 40"...
10222 (A56858)
10222 (A56858)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2007 Ford F-550 Crew Cab 11ft Flatbed Truck (A55852)
2007 Ford F-550...
