quad shift has mind of its own
   / quad shift has mind of its own #1
redman135
nz
Case 105c
2015 JD6170M, quad shift gearbox.
Job, towing 15 ton tandem trailer on earthworks.
problem, quad shift in 1 in a,b, or c range , engage drive lever, (forward), and the quad shift starts in 3 AFTER you have specifficly shifted to 1. This only occurs going forward, not in reverse.
This is a problem because of the soft groud. B1 starts , but B3 will often stall.
I have driven 6910,6920 and 7430 quad shift tractors and never run into this problem.
What terms should I be looking for in the manual?
   / quad shift has mind of its own #2
Do you have PowerQuad Plus? Or AutoQuad Plus transmission? If AutoQuad Plus it might programmed to ECO mode?
There is an auto shift buttton on this (6170m) tractor. I haven't had auto shift before.
At least I have some idea of what terms to look up,(that is half the battle) thank you zebrafive
Hello zebrafive, it wasn't under 'eco' but you got me on the right track. Some meddlesome monkey had gone into the "start gear" menu and shifted the start gear from 1st to 3rd. Shifting the start gear back to 1st solved the problem.
   / quad shift has mind of its own #5
I am glad I was some what of a help. I am guessing a AutoQuad Plus transmission then.
Yes AutoQuad Plus. It would have been excellent on bale stacking, but on this earth works job the rough haul track means it is more comfortable to run in manual mode.
   / quad shift has mind of its own #7
At least you did not have an electronic or mechanical problem, just someone reprograming the controls, which you were able to correct.
2011 WABASH 53x102 DRY VAN (A53426)
2011 WABASH 53x102...
6 FOOT UTILITY TRAILER WITH MOTOR (A53843)
6 FOOT UTILITY...
WOODS DS8.30 LOT NUMBER 52 (A53084)
WOODS DS8.30 LOT...
2016 Chevrolet Malibu Sedan (A51694)
2016 Chevrolet...
2012 Chevrolet Silverado 1500 LTZ Crew Cab Pickup Truck (A51692)
2012 Chevrolet...
2016 FREIGHTLINER CASCADIA (A53843)
2016 FREIGHTLINER...
