1705 carry all
   / 1705 carry all #11
Edgarrian
Thanks for the info.
I'm not keen on modifying, but will probably try as is and see if I have enough ground clearance for my needs.
The closest 3 TSC stores are out of them so I'll have to order it online or range farther to pick it up in a store.
   / 1705 carry all
yea no problem the other guys pictures were helpful. Ill have to check my tsc store when i fly back from work.
Edgarrian
   / 1705 carry all #13
I saw someone sells a 3ph ballast bo, but 2x$$ of county line/KingKutter CA.
I was thinking I would build a wooden box for the CA, to carry other stuff .
   / 1705 carry all
yea much cheaper alternative for ballast plus you can have other uses for this as well.
   / 1705 carry all #15
I ended up getting the one from TSC.
Easier to modify than KK CA.
Put a pair of new holes 6" below original lower ones and now it lifts to 14" above ground.
It was easy enough to put new holes in, with a magnetic base drill I borrowed from work & 7/8" drill bit.
It wouldn't have been too hard to do on my drillpress at home but...
I'll attach boards & strap sandbags on for ballast.
Then I'll probably build on a detachable box in the spring.
   / 1705 carry all
14" above by moving the holes 6 inches. thanks for the info. I have my gift cards ready just need to get to the store.
   / 1705 carry all #17
So Karondm, you got one of those County Line carryalls? What did you do --or did you-- lower the top link connection to gain your ground clearance? (Or is that even necessary?)
   / 1705 carry all #18
Irvingj
Yes, I did get the County Line one.
I put new holes in, 6 inches lower, but did not change the top link.
That makes the carryall tip up as I lift it, which is ok for my winer use as ballast rack.
I will consider adding a lowered top link connection in the summer if I need the unit to stay closer to level.
But, that means I would have to add a lower top cross bar to do that.
Adding a lower top link connection means bringing the carryall back to work for more new holes on the uprights and i think I've already carried it around in my open trunk enough for one winter!
Zero Turn Mower (A55853)
Zero Turn Mower...
UNUSED FUTURE SB45 HYD SILENT BREAKER (A52706)
UNUSED FUTURE SB45...
Moffett M5000 Truck Mounted Forklift - 5000 lbs Capacity - Side Shift (A55315)
Moffett M5000...
2010 Blue Bird BB Conventional School Bus (A55852)
2010 Blue Bird BB...
2013 Toyota Tacoma Crew Cab Pickup Truck (A55852)
2013 Toyota Tacoma...
2007 FORD F-150XL TRITON TRUCK (A57192)
2007 FORD F-150XL...
