1975-77 3 cyl. ford diesel tractor with C.A.V. fuel injector pump problems
   / 1975-77 3 cyl. ford diesel tractor with C.A.V. fuel injector pump problems #1
gtflyboy
Greenfield Twp. Pa.
ford/kubota
I have a 1975/77 3 cyl .ford diesel tractor with a C.A.V. diesel injection pump Mfg. No. 3233F641. It was running just fine for many years until a month ago. I drained the fuel tank /cleaned the filter container /replaced the filter/ I noticed when doing this quite bit of condensation and milky fuel in the fuel supply . I again tried to start it after bleeding the system of trapped air . No luck .It still refused to attempt to start ..Next I pulled the injection pump after marking the timing marks .so I would not disturb the timing . Upon first removing the top cover exposing the governor /throttle /fuel shut off linkage , it was evident it needed to be disassembled and cleaned. When I began the process, The first thing I noticed was The small cover plate on the side with the pressure relief valve which sends fuel back to the filter had come apart and a small spring 5/8 in. long and approx. 3/16 in width was found and a small which seems to be a washer ,But no check ball was ever found (perhaps washed away in the cleaning process? All the valves /pistons/ where cleaned in the primer pump as well as the high pressure pump and seem to be working properly ..What I want to know is are all these covers with these pressure relief valves which returns fuel to the filter assy. the same in all these C.A.V. rotary pumps? I also noticed there was no( dumb-bell valve) located in the cavity behind the primary transfer pump liner where this valve was shown according to( some) of the rebuild manuals and parts diagrams I downloaded from the internet. I also noticed the large circlip was not positioned in the center of the inspection hole according to the repair manuals I downloaded which has to do with the timing of the pump before its even attached to the tractor. I would appreciate any help from anyone who is familiar with this model pump C.A.V rotary fuel injection pump .( Mfg. no. 3233F641) for the above stated 3 cyl. ford tractor . Also If anyone has This side cover with fuel return valve which I could purchase.. Thank you and a Merry Christmas to you all. gtflyboy
   / 1975-77 3 cyl. ford diesel tractor with C.A.V. fuel injector pump problems #2
The side covers are different pressures.. Yours is a Delphi P#> 7180-57A
The C clip is not used by Ford for timing. Its normally turned around in the housing, opposite the side cover opening.
IF it has a flat on 1 end of the clip, you could use it if you wanted to.. some have 1 flat for timing and 1 rounded end.
and some, ford, has 2 rounded ends..
If you want to use it.. apply air pressure to outlet W and turn the drive shaft CLOCKWISE, looking at the driveshaft, until it stops.. that's the start of injection, and just move the clip to line up a letter. punch and hammer.
Final timing is done on the * marks on the flange of the pump and block.. set at "0"*
Merry Christmas..
Problem finally solved : I Purchased a rebuilt injection pump . Thank you all for helping me make the right decision .. Have a nice day
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A53472)
Kubota 24in Quick...
(4) 55 GALLON POLY DRUMS (A51248)
(4) 55 GALLON POLY...
2020 GENIE TZ-34/20 TOWABLE MANLIFT (A51242)
2020 GENIE...
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
2017 KENWORTH T4 CONCRETE MIXER TRUCK (A51243)
2017 KENWORTH T4...
UNUSED GREAT BEAR 1.5CY SELF DUMPING HOPPER (A51248)
UNUSED GREAT BEAR...
