Timbren rear suspension system ??
   / Timbren rear suspension system ?? #1
coobie
Super Member
S.Michigan
Kubota RTV 1100c, JD 740,Kioti DK 40 with KL401 loader .
Considering purchasing the Timbren rear suspension enhancement system for my 2016 Ram 2500.Anyone have this system installed?Good or bad,thoughts?Thanks..
   / Timbren rear suspension system ?? #2
I would go with air bags. I tried the Timbrens twice. Was not that impressed.
Now I buy the proper trucks. To me 3/4 tons of any make leave too much to be desired. I only but 1 ton SRW. For less than a grand usually you gain a bottle 1500# of payload
   / Timbren rear suspension system ?? #3
OP, I had the same thought with my F150. The suspension is great for every day commuting but lacks when loaded. I went with Timbren and the install was quick. I also went with just the rubber and left off the axel pieces. This gives me 2" of travel before contact. Still a good ride until it's truck time.
Been great so far and I've loaded it to the max+. I'm sure the airbags are good too but that's not what I went with. Too much plumbing and cost. Plus even more $ if you go with on board air.
-R
The reason for my 3/4 ton purchase verses 1 ton is everyday driving plus occasional heavy towing.1 tons IMHO knock your teeth lose for everyday drivers.
   / Timbren rear suspension system ?? #5
I notice no difference. I had a 04 F250 and a 06 F350 at the same time. The F250 was the heaviest version with a 10,000# GVWR and same with the SRW F350 at 11,500# GVWR. In between I had a 05 GMC Dmax 3500 but it's GVWR was only 9,900# and was actually less truck than the 04 F250 in a multitude of ways.
We have about 75 1 ton SRW GM Trucks 90% are Dmax and the ride seems decent also.
Boy I sure notice every time I ride in my best friends 2012 ram 3500.You feel every bump in the road.
   / Timbren rear suspension system ?? #7
Air bags may offer more advantages such as being able to keep the truck level.
My truck does not sag much with a heavy load just slightly.The reason I thought about the timbren set up verses air bags.Thanks.
   / Timbren rear suspension system ?? #9
I would also suggest the air bags. My Dad tried the Timbrens and did not like them. He said they worked good loaded, but when unloaded it was nasty everytime you hit a bump. I have always used the air bags and been happy.
   / Timbren rear suspension system ?? #10
Haven't looked into timbrens but timber grove makes an air suspension for our rams that requires no cutting or welding and it is solid. I'll try to get some pics of mine.
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
1989 Ford LT9000 Log Truck, VIN # 1FDZU90T2KVA25137 (A57453)
1989 Ford LT9000...
IRanch Mini 38" Grapple (A57149)
IRanch Mini 38"...
Year: 2014 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 (A55852)
Year: 2014 Make...
1700 (A58375)
1700 (A58375)
(2) 48" HANG ON FORKS (A54757)
(2) 48" HANG ON...
