X734 where is hydraulic diverter valve?
   / X734 where is hydraulic diverter valve? #1
Deadman
WI
John Deere 2520, X475
I just bought a new JD X734 and I removed my mow deck and put the front quick hitch on it with my broom for sweeping snow and the left to right action on the hydraulic function has a 5 second delay in it. I'm assuming it needs a diverter valve turned somewhere, but I have no clue where said diverter valve is located. Its not where the diverter valve on my X475 is.
Any thoughts or suggestions?
Thanks
   / X734 where is hydraulic diverter valve? #2
Deadman that should be located down behind the SCV valve, on the back side from where
the quick couplers are. you should see a small black wheel that you turn and shut off
for winter use, and open back up for summer/mower deck use.
if you had the x475, it uses the same diverter, you know where it should be..
if it's not there, it may have never been installed when the hitch was installed,
contact your selling party/dealer/etc...
bingo, never got installed…….crap. I assumed it was a factory part! Arghhhh
Thank you!
   / X734 where is hydraulic diverter valve? #4
I think it was optional equipment, not standard equipment. Well, it was for my older x495
   / X734 where is hydraulic diverter valve? #5
It comes standard with the front hitch angling kit but not with the tractor itself.
   / X734 where is hydraulic diverter valve? #6
That's a good thing. I cussed the 5 second delay for a long time until I found out I could buy a diverter valve to fix the problem.
That makes perfect sense. I bought that X734 outright and kept the quick hitch to reuse from my old X475, so the diverter stayed with the X475. I'll get a new one and get it on.
Thanks guys!
   / X734 where is hydraulic diverter valve? #8
great,
love easy fixes!
:D
AMADAS 2100 LOT NUMBER 255 (A53084)
AMADAS 2100 LOT...
2020 FOR TRANSIT CONECT CARGO VAN (A52577)
2020 FOR TRANSIT...
378492 (A51572)
378492 (A51572)
2017 Kia Cadenza Premium Sedan (A51694)
2017 Kia Cadenza...
2014 PETERBILT 386(INOPERABLE) (A52472)
2014 PETERBILT...
