Tire grooving with my chainsaw
   / Tire grooving with my chainsaw #31
They look real nice! I can't believe you could control the saw that good! I'm impressed!
You won't believe the difference it makes. The R4's are nearly useless in snow and ice before being cut and after being cut they do really good! I cut the fronts across the lugs, so I had side traction, because it always slid sideways before they were cut.
   / Tire grooving with my chainsaw #32
Are you one of those guys that carves the bears out of a large tree stump? lol
   / Tire grooving with my chainsaw #33
Well in that case, I'm golden. :)
In all seriousness, I'm sure that the placebo effect plays into it. Furthermore, I don't claim any immunity from it. That's a big part of why I didn't want to spend $100 on a grooving iron. I'm not expecting a dramatic traction increase. But hey, I've got less than a half an hour into this project. I don't think it'll make anything worse, and might make things a little better. Even if it's only in my mind. :)
They'll have 3x the traction, on hard packed snow. Its amazing we suffered thru them with no grooves as long as we did!
   / Tire grooving with my chainsaw #34
I think whether they are successful or not is dependent on expectations.
Definately an improvement over stock R4: whether that's good enough, YMMV.
I have no trouble plowing [675' gravel driveway] but they don't help in the woods.
   / Tire grooving with my chainsaw #35
Quantifying the results would be hard to do. Soooooo many variables involved. :)
   / Tire grooving with my chainsaw #36
If you THINK you went through that drift and up that hill, you DID go through that drift and up that hill.
Bruce
Bruce
I think I can, I think I can, I think I can!!!
You're absolutely right. I have a hill behind the shop that my New Holland can't make it up, even just pulling itself. Since the chainsaw method was so fast, I should have done a before and after video. The half hour would have limited the amount of change in conditions. I, however, didn't think of it at the time.
   / Tire grooving with my chainsaw #39
You won't need to qualify them. They're so much better you will want to forget the old slicks slip-sliding non stop.
I rarely use 4x4 in the snow now, and before I couldn't move in just 2wd. Thats with 1,000lbs ballast on the back and FEL on front.
   / Tire grooving with my chainsaw #40
If proof of improvement to you is conditions where you don't even need 4wd now I believe your standards definitely need quantified. :)
2006 FORD F-150 PICKUP (A54313)
2006 FORD F-150...
2019 Chevrolet Silverado 3500HD 4x4 Crew Cab 10FT Flatbed Truck (A51691)
2019 Chevrolet...
2024 Cynergy Cargo 2 Enclosed Trailer (A53117)
2024 Cynergy Cargo...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A52377)
2015 Chevrolet...
2021 Chevrolet Corvette Stingray C8 LT1 Convertible (A51694)
2021 Chevrolet...
