Comparing SUDT2 and Deere Hy-Guard in M6800-M7040 hyd shuttle transmission
   / Comparing SUDT2 and Deere Hy-Guard in M6800-M7040 hyd shuttle transmission #11
pretty much exactly what you said. Easier shifting, less whine. Most evident in hydrostatics, RTV in particular can be really fussy with the wrong HST fluids.
Yep, I noticed a marked improvement in my RTV. :)
   / Comparing SUDT2 and Deere Hy-Guard in M6800-M7040 hyd shuttle transmission #12
Maybe I should use it in my "fake orange" machine. It is coming up on the 400 fluid change pretty quick. I wouldn't be against trying it.
If you have a shuttle shift or hydro, I'd look into it. Does Kioti have a syn or semi-syn fluid?
   / Comparing SUDT2 and Deere Hy-Guard in M6800-M7040 hyd shuttle transmission #14
not that I know of..
Not sure. Maybe investigate among other Kioti owners to see what they have done. Someone here must have used it.
   / Comparing SUDT2 and Deere Hy-Guard in M6800-M7040 hyd shuttle transmission #16
I priced some of it today, and it is not much more than the 424 Mobilfluid I have been using, and by having a synthetic component, if I could get some cold weather flow improvements, I am seriously considering it. I notice some sluggishness until the fluid warms when it gets cold around here.
I looked up that 424 Mobilfluid that you mentioned Mobilfluid 424 and it meets Kubota's UDT fluid only and not the SUDT2. So I would say it's not synthetic.
Other tractor manufacturers need to get their act together and start making synthetic trans fluid to compete with Kubota.
   / Comparing SUDT2 and Deere Hy-Guard in M6800-M7040 hyd shuttle transmission #18
Or we can just go to our friendly Kubota dealer and ask for some fluid!:) I ain't proud..:)
2012 Freightliner Cascadia - Class 8, 6x4, Detroit DD13 (A52748)
2012 Freightliner...
PAIR DIAMOND PLATE DBL AXLE FENDERS (A51247)
PAIR DIAMOND PLATE...
BANDIT ZT1844 RUBBER TRACK STUMP GRINDER (A50458)
BANDIT ZT1844...
UNUSED WOLVERINE CB-11-750F HYD CONCRETE BREAKER (A51248)
UNUSED WOLVERINE...
2005 GMC 8500 (A50123)
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A53426)
2019 FREIGHTLINER...
