Is a welded cylinder much better than a tie rod cylinder?
   / Is a welded cylinder much better than a tie rod cylinder? #1
Fallon
Super Member
Parker, CO
Kubota L4060hstc, formerly L3200hst
Researching cylinders for a hydraulic SSQA project. Other than the welded cylinders being less bulky, are they generally better than tie rod cylinders?
   / Is a welded cylinder much better than a tie rod cylinder? #2
Never really gave it much thought. I like welded because they are a cleaner cylinder. Just a nice smooth tube. No bulky square ends and tie rods that catch/hold all kinds of dirt and debris.
They also dont have to worry about cap seals
   / Is a welded cylinder much better than a tie rod cylinder? #3
A leak on a tie rod style cylinder will almost always lead back to a seal or o-ring failure.
A leak on a welded cylinder will be a leaking rod seal, or a failed weld on the base end.
I've seen plenty of failed welds on all types of welded cylinders.
properly selected and with proper application design parameters, either will work well.
Flip a coin, buy on price, whatever. Neither style has a clear advantage in my book.
   / Is a welded cylinder much better than a tie rod cylinder? #4
From what I have read, Most Tie Rod Cylinders are limited to 2,500 PSI.
   / Is a welded cylinder much better than a tie rod cylinder? #5
2,500# continuous flow but a 4" bore has 31,400 lb. force.
   / Is a welded cylinder much better than a tie rod cylinder? #7
Tie rod cylinders are more likely to meet NFPA specs and certification. This is usually more important for industrial use for replacement. Typically a welded cylinder will be smaller & lighter for the same bore size so the are far more common on mobile equipment.
   / Is a welded cylinder much better than a tie rod cylinder? #8
Have not seen any Excavators with Tie Rod Cylinders on Them ?
Thanks for the info. Still leaning towards welded, but might go tie rod if I find one for the right price.
Need at least 2,500lbs rated cylinders as that what my tractor is & I don't want to double or triple the cost of the project getting an extra relief valve. Going with the smallest cylinder I can get as a 100lbs rated linear actuator did the same job on my old tractor. 1" or 1.5" tops.
   / Is a welded cylinder much better than a tie rod cylinder? #10
Just make sure the stroke length is correct so you don't bend something up.
2016 JOHN DEERE 624K WHEEL LOADER (A51246)
2016 JOHN DEERE...
2012 Ford F-150 Ext Cab 4x4 Pick-Up Truck (A55852)
2012 Ford F-150...
2024 KMC 7406 LOT NUMBER 11 (A53084)
2024 KMC 7406 LOT...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A52707)
KNOW BEFORE YOU...
2000 FORD F-350 SUPER DUTY BUCKET TRUCK (A52472)
2000 FORD F-350...
Forestry Truck Grapple and Frame (A55851)
Forestry Truck...
