Used Greenhouse
/ Used Greenhouse #1
jjbenson
Member
Zanesville, Ohio
Kubota L3400 and Massey 65 Mark II Dieselmatic, Bobcat 863H, Yanmar B50 Excavator, CAT E70B excavator, Massey 245
Hey everyone, I'm looking at buying a used greenhouse. I'm just not sure what to pay. It's a Decloet, gutter connect. 24x60. The top needs replaced, but the polycarbonate sides all look like they are in great shape. It has two circulating fans that work, and two large fans on the end walls, with louvers at the opposite end, that all work. It also has a garage door. I know at this point I'll need to disassemble, buy new feet(the old are in concrete) buy a new cover, and possibly replace some wiring. I have equipment to do all the work-I'm just not sure what to offer the owner. He started at 10 grand, then went to 5, and now its make an offer. I know at this point, factoring in new concrete and sonitubes for the feet, gravel for the inside, a new cover, and possibly a few sheets of polycarbonate, I'm looking at about 1000.00 in material just to get it weathertight. I'll try IMG_2867.JPGIMG_2869.JPGIMG_2868.JPGto include a few pictures below. Any ideas on a value? I'm not even sure what a new one costs...
/ Used Greenhouse #2
So basically your buying a shell with 2 fans and you have to spend money to even put it back up and you have to remove it from his place? I would offer $2K max. Yeah, he has way more than that in it but it's not on wheels and isn't easily removed, he has to get past that.
/ Used Greenhouse #3
Looks like a nice project... I have been thinking about getting one but don't really have the time currently..
/ Used Greenhouse #4
I would start lower and have a max (I was thinking $1500 max), you already know you have a bunch of work to do just to move it and a bunch more to put it together...
/ Used Greenhouse #5
Decloet makes a good product. I'd suggest pricing a new frame from them in the size you're looking at. Also, those polycarbonate panels aren't cheap. I wouldn't put much value in the fans and wiring, but the frame and panels are worth a decent amount, even if you have to disassemble it.
For reference, I bought a used poly-tek 30x96 hoop house a couple years ago. I paid a little less than half what a new one would cost, but the poly was only a year old and it had two layers (that's $1000 right there). Same as you, I had to leave the feet behind and buy new ones. One thing I'll mention, is that you could skip the sonotubes. We used a post hole digger and put one bag of concrete in each hole. Also, drilled a hole in the bottom of each ground stake and stuck a nail through it for grip in the concrete. By the way, finding the feet/ground stakes was very expensive. We ended up buying galvanized pipe locally and using that. Saved a lot of money over what the manufacturer wanted for the swaged tubing.
Last piece of advice. If you are going to disassemble the greenhouse yourself, bring along your 1/4" cordless impact driver and the adapter to run sockets. If you don't have that setup already, go buy it. It's worth it. There's lots of fasteners holding that frame together. You don't want to be there with a ratchet all day.
/ Used Greenhouse #6
There are a ton of those around here because you can get a USDA grant to put one up for basically free. The manufacturers promote it heavily. Here's an example:
Understanding the NRCS High Tunnel Program - Rimol Greenhouses
I believe under the terms of the grant you have to keep it up for four years.
Since new ones are essentially free used ones don't have much value.
/ Used Greenhouse #7
Contact Decloet and ask them for a quote on the same/comparable setup. Go from there. farmtek.com has pricing on their website; maybe you can get a general idea of costs from something comparable there.
I've constructed and disassembled the same 14x36 greenhouse 3 times, and it is a LOT of work. Don't ask why 3 times. :eek: :confused2:
/ Used Greenhouse
Thanks for the info motownbrowne! Surprisingly, i have not been able to get Decloet to to price a new one, or get a price on legs for an existing one. They must be busy... I was thinking of skipping the sonotubes actually, I'm glad you mentioned it, it re-enforces my original thought. I will call my local fab shop tomorrow, and get a rough estimate on them custom making 12 feet for the side posts.
/ Used Greenhouse #9
You betcha. Glad to be of service. I didn't realize that the grooves stakes are 12' long. If I were you what I would do is cut them off at the ground with a sawzall and bring them with you. Then set a slightly smaller pipe into your holes with concrete. Then slide the pieces you cut over the pieces in the ground. You can use a self-tapping screw as a stop on the inner pipe, and then 2 self tapping screws though both pipes. I'd want 18" or more of overlap. That's how mine is done, and it's very solid. I just bought galvanized pipe at home depot, i think it was sold as chain link fence posts.
Also, those NRCS grants are pretty cool. They aren't a guarantee, though. A friend of mine was just declined. Basically there's a rating system for who gets them. Beginning farmers, minorities, etc get priority. Also, if you already have a hoop house erected, you can pretty much forget getting a grant. Worth applying for, though.
/ Used Greenhouse
I've read up on the NRCS grants, but I don't think what I'm looking at now would qualify. I think I read they were for Hoop houses only. I don't believe what I am looking at, which is what I want, would qualify. I need something I can grow trees in, and work on equipment on and off out of the weather.
/ Used Greenhouse #11
I helped a neighbor put up a greenhouse he got through a NRCS grant this summer. It was a Rimol Nor'Easter: Nor'Easter Greenhouse - Durable Production Greenhouse
NRCS definitely will not allow you to use it for storage, they were very clear about that, that's immediate disqualification.
The framework was all the same as chain link fence pipe, 13ga. If I needed to replace a few straight sections I would just go to a local fence dealer.
/ Used Greenhouse
Well, I picked up the greenhouse for 1200. After pricing them from a partial price list, I assume this unit was about 10-12 grand without the 4 fans, not including the small ones used to inflate the space between the two layers of roof plastic. I'm excited. I'm going to try to get some more pictures up, and document the whole dis-assembly, site prep and re-assembly.
/ Used Greenhouse #13
Nice work! That's a heck of a deal.
/ Used Greenhouse #14
Awesome, take some picture for sure. It will be fun to see your take down and build.
