S373 Beaver III front hydraulic pump shaft for Blackhawk FEL is TOAST! HELP!!!
   / S373 Beaver III front hydraulic pump shaft for Blackhawk FEL is TOAST! HELP!!! #1
pswift408
melvin village, NH
satoh beaver 3 4wd
Has anyone run into this problem before? Can't find anything on the internet that could possibly replace this. Getting new yokes,u-joints etc to build one is tough to find also, due to the short length and small 9/16" round keyed shafts at both ends. Any help would be great! Thanks,Paul
   / S373 Beaver III front hydraulic pump shaft for Blackhawk FEL is TOAST! HELP!!! #4
I have a worn U-Joints/shaft on mine as well, must repair it soon, I have the parts, just need to spend some lathe time to fit it all together.
( I hope I have all the parts?)
American G-Model Pump Jack (A56435)
American G-Model...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
1104 (A58374)
1104 (A58374)
NIPPON HYD THUMB (A52706)
NIPPON HYD THUMB...
2012 Ford F-550 Knapheide Service Truck with Liftgate (A56858)
2012 Ford F-550...
Magnum 4000 Series Hot Water Pressure Washer (A55272)
Magnum 4000 Series...
