Roger66
I Know I'm researching this to death and beating a dead horse. If you've seen my previous posts I'm looking to buy a Mahendra 1526 based on the specs it seems to win over all others. I always imagined myself buying a JD or Kubota, but the spec keep swaying me to the Mahindra. Not trying to start a brand war or in any way belittle another brand here. I'm just new to this and I want to make sure my comparisons are acurate
According to Kubota's own comparison see link below. It seems like Kubota is telling me to buy the Mahindra.
404 Not Found
Am I missing something?
The 1526 is longer, wider, shorter (Should be more stable), Tighter turning radius has double the 3 point lift capacity and more hydraulic flow.
The Kubota has a Larger lower RPM engine, slightly more PTO HP, a little more weight more optional rear hydraulic ports.
Of these the only significant feature here is perhaps the larger lower revving engine, perhaps it may outlive the Mahendra? The PTO HP is marginal, the weight can be added, I can add hydraulic ports easily.
What are the Arguments for the Kubota?
Thanks
404 Not Found
Thanks
