L3940 Rear Snow Blower --> Front Blower?
   / L3940 Rear Snow Blower --> Front Blower? #11
I'm a fan of the Erskine front-mounts that drive from the standard rear pto. Erskine stuff is well-built and very rugged - will last a lifetime - no worries about buying used. They make several widths - 72" would work well with a L3940. As an example here's a current Craigslist ad for a used five-foot Erskine for $2k in Wisconsin. (Road trip ??)
Pics below are my 6' one that's been stretched.
   / L3940 Rear Snow Blower --> Front Blower? #12
My BIL has a six ft.Lofness,rear PTO driven blower that he would like to sell.$2500.Off a L3300 Kubota that only had 176 hours when purchased.Only problem it's in Northern NY state.
   / L3940 Rear Snow Blower --> Front Blower? #13
6' is great for an L3940, and it's 1/4 the cost.
Can you run a back blade with the loftness?
   / L3940 Rear Snow Blower --> Front Blower? #14
No,the gear box and sub-frame take up that space.Quite a robust system.The FEL must also be removed.The tractor/blower was only used by a home owner to do his own drive.We installed the FEL after purchase and removing the blower.
Looks like the one rbargeron posted(see rear view).
   / L3940 Rear Snow Blower --> Front Blower? #17
If you're concerned, use synthetic. I'd say it's no issue though. A few minutes of circulation and it's good to go.
   / L3940 Rear Snow Blower --> Front Blower? #18
GarthH
I am 70 and have a fused neck and damaged spinal cord.
My savior has been an inverted snow blower where you pull it so most of the time you are looking forward not backward.
I installed a blade on the rear of the blower so I can back up to a garage door and pull the snow forward, then I raise the blade back up, drop the blower and no shoveling required.
For my two brothers homes, I have garage door remotes so I open the garage door, drop my blade, back into the garage a little, drop the blower which drops the blade and pull forward. They don't have to shovel at all.
No front blower can do that except the very expensive ones that rotate the whole blower to become an inverted one.
Smyth Welding,Normand, Pronovost are Canadian manufacturers of good solid equipment.
Dave M7040
GarthH
Dave M7040
Wow that is one interesting idea. I do not notice a drive shaft so it must be a hydraulic blower? I did not notice it on the Smyth Welding website was it your design?
Thank you
Garth
   / L3940 Rear Snow Blower --> Front Blower? #20
Thank you
Garth
Look closely behind the tractor tire, the PTO shaft is there pointing straight down...
Pretty sure the blower wasn't hooked up in that picture.
Aaron Z
Adams 6T Fertilizer Spreader (A53472)
Adams 6T...
(2) UNUSED 3500# BRAKE AXLES (A51247)
(2) UNUSED 3500#...
2007 Ford Focus Hatchback (A51694)
2007 Ford Focus...
2005 CATERPILLAR D3G LGP CRAWLER DOZER (A51246)
2005 CATERPILLAR...
UNUSED HURRICANE F10 10' WROUGHT IRON SITE FENCE (A51248)
UNUSED HURRICANE...
9ft x 7ft Shipping Container with Side Door (A51573)
9ft x 7ft Shipping...
