Ballast Loaded R3's on a sidehill?
   / Loaded R3's on a sidehill? #1
LD48750
SE, MI
Ford 1510 Mahindra 1526
Does loading Turf tires lower the CG of the tractor?
I have a sidehill I mow that is right at the edge of my comfort level now & I just loaded front & rear tires on my Ford 1510.
Am I going to be in trouble?
   / Loaded R3's on a sidehill? #3
It'll be more stable with loaded tires, as Deere dude said.
   / Loaded R3's on a sidehill? #4
The center of gravity is your metric. If the center falls within the span of the rears you should be good to go. Anything below the CG and within the confines or the rears helps with stability. The lower the mass the less required to get the desired result. Loading tires is about as low as you can get.
Couple of other things to consider:
1. Hitting a bump transfers the CG instantaneously and can result in an unpredictable result. Speed hinders since the faster you go and the larger the bump, the more energy involved to overcome your normal CG.
2. Sliding down the hill is always a problem, especially on wet grass like is encountered when you are mowing in the mornings before it gets too hot. A loaded R1 on a suitable soil (soft enough for lugs to penetrate and hold), reasonable hill side (30 degree is getting pretty risky with no other gotchas) may hold just fine. Otherwise you are asking for trouble.
   / Loaded R3's on a sidehill? #5
Better loaded, and turfs are better on slopes than industrial. They tend to slide sideways.
Ralph
Well ..... I have been mowing it the last 10 yrs or so with my 2N and a 72" 3pt finish mower.
Last yr I got the 1510 with a MMM and it worked but is still as I said, right at my comfort level.
MMM is off for winter & I may use the 3pt to start the season but will have the MMM back on soon.
   / Loaded R3's on a sidehill? #7
If your gauge wheels are off the ground that MMM is the perfect CG reducer.
2021 Kubota SVL75-2 Track Loader (A56438)
2021 Kubota...
Kubota B21 TLB (A60462)
Kubota B21 TLB...
2025 Safety Basket Forklift Attachment (A59228)
2025 Safety Basket...
2011 Toro Multi Pro 1250 Sprayer Cart (A59228)
2011 Toro Multi...
2003 Big Tex 10PI...
2021 Billy Goat F902H Walk-Behind Debris Blower (A59228)
2021 Billy Goat...
