Domestic Tank Hot Water Heater Trouble
   / Domestic Tank Hot Water Heater Trouble #51
Saw a home recently on a slab with the water heater about dead center... the heater was on a pan that drained to a gravel area about 12" square.... looks like someone just cut a hole in the slab and dug it out and then filled with rock.
There is always gavel under a slab. And, depending on how well it was compacted when it was filled, there can be a sizable void over time.
It's a big french drain. And, it can potentially take a lot of water.
A floor drain, or sump, should be near by the water heater, when it's located on a slab, in any case. Not doing so, is poor planning.
What do you folks, who are familiar, think about "tank boosters"? Any better or worse for tanks?
   / Domestic Tank Hot Water Heater Trouble #54
Speaking of water heater drain pans and drains, what do you all use to keep outside insects/other critters from coming up the 1" drain line to the pan? Do you put a trap in the drain line?
I had been seeing a few mosquitoes around my water heater and finally figured out that they were flying up the drain pipe from my crawlspace. I placed a piece of toilet paper loosely in the line (figuring it would get soft and fall down the line if there ever was a leak) but I know there must be a better way.
   / Domestic Tank Hot Water Heater Trouble #55
You could put a trap in the line, and fill it with antifreeze.
You could also, bush the discharge end up to a larger size, and fit a piece of wire screen in it.
2014 VOLVO A25G ARTICULATED DUMP TRUCK (A51406)
2014 VOLVO A25G...
2012 Volkswagen Jetta Sedan (A53424)
2012 Volkswagen...
2013 UTILITY DRY VAN TRAILER (A54607)
2013 UTILITY DRY...
2020 Deere 325G (A50123)
2020 Deere 325G...
UNUSED WOLVERINE LHR-51-23W 1R RIPPER (A54757)
UNUSED WOLVERINE...
2004 Sterling Acterra Cab and Chassis S/A Truck (A54814)
2004 Sterling...
