cutting holes in steel gate post for hinge bolts
   / cutting holes in steel gate post for hinge bolts #1
Bob1476
What is the easiest way to make holes in a steel gate post to install hinge bolts (that go all the way through the post)? I don't have a cutting torch. Is it possible to drill the holes? The gate post is made of 2 7/8" steel tubing. Thanks.
Bob
   / cutting holes in steel gate post for hinge bolts #2
Seems like an electric drill is the way to go. I don't know of any other practical way.
   / cutting holes in steel gate post for hinge bolts #3
I would drill it through with a smaller bit first, keeping great care to keep it level and square to the pipe. This will be easier to do with a smaller bit. You will likely need a longer than "jobber length" bit to do this. Then I would drill it from both side with the larger bit you will need to pass the bolts. Take great care as you start to break thru, as the larger bit will likely grab and seize and try to break your wrist with the drill. As you start to break thru, back way off of the pressure. A drill with a another right angle grip for the other hand can help here, or switch to a portable drill with a clutch to make the final breakthru. Drilling big holes in pipe with big powerful drills can be painful. Some lube as you drill can be helpful.
   / cutting holes in steel gate post for hinge bolts #4
Solid advice James. MAN, that makes your wrists hurt if done wrong........ Not that I ever have........ ;)
   / cutting holes in steel gate post for hinge bolts #5
No, I wouldn't know anything about using a huge 5/8 drill to drill a 5/8 hole with a twist bit thru a big piece of pipe buried in the ground in concrete, and having it just about twist me into a pretzel.. no, I wouldn't know anything about that at all...:rolleyes:
   / cutting holes in steel gate post for hinge bolts #6
I had an old Sears 1/2" drill that seemed like it would run for 10 seconds after letting go of the switch...... What a drill!!! :)
   / cutting holes in steel gate post for hinge bolts #7
It all depends on wall thickness too. Is it round or square tube? What size bolts? I like to fill tubing with concrete. Keeps the water out and makes it just a bit more ridged. This makes drilling holes later more fun.
My challenge is always to keep the drill perpendicular. It helps to have someone with a good eye watching.
My dad still has that craftsman 1/2" geared down cast drill with the twenty pound trigger pull, on/off switch. As a hundred and twenty pound teenager that thing just about ripped my arm off a time or two and many times ended up wrapping it's cord around itself. I bet, that cord is still like new. QUALITY! It had the 1/2 inch pipe you could thread into the top for holding onto and a D handle you could attach to the back.
   / cutting holes in steel gate post for hinge bolts #8
Yep, I had the D handle. Lost mine in my shop fire. You can't buy anything like that now. That Drill was a Love/Hate relationship. :D
   / cutting holes in steel gate post for hinge bolts #9
I know what you mean. That 5/8 drill was so geared down it probably didn't turn more than about 180 RPM, and had "ship" loads of torque, which was good and bad.. That thing could twist you off of a ladder in a heartbeat.
   / cutting holes in steel gate post for hinge bolts #10
Yes. There was "mass" in movement with those old drills. Took a bit for all that to stop moving!!!! :D
Doosan Thumb (A47477)
Takeuchi TL150 Skid Steer (A54865)
Takeuchi TL150...
Toro Z Master 2000 Zero Turn Mower (A50324)
Toro Z Master 2000...
2008 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A55745)
2008 DRAGON 150...
2024 Big Tex 14GN-40D5A 35ft Gooseneck Flatbed Trailer (A51691)
2024 Big Tex...
PALLET OF SCAFFOLDING (APPROX. 18 PC) (A52706)
PALLET OF...
