MF 461 Clutch "Groan"
   / MF 461 Clutch "Groan" #11
AGCO shows that as what we always referred to as a button clutch. Yours has 5, pads, or buttons. We had them in some of our dump trucks at work. The groan is just the nature of the beast.
As Banjodunn said, they bite harder, more pressure psi. There was one in my '58 Case 310B backhoe, but metallic type. Appeared to be the original, and still looked like new, and surprisingly, so did the flywheel.
Here is the part number if you want to copy, and paste to Google, and see what it looks like. 3701008M91
Great info. Thanks DJ54. I appreciate the response.
   / MF 461 Clutch "Groan" #13
I'm guessing that what you are hearing is clutch chatter. It's caused by uneven clutch and pressure plate surfaces. I would drive it until you need to replace the clutch. When you do that make sure you either replace the flywheel of get it resurfaced by grinding it until it's all flat again.
I watched the video and now I'm even more convinced that it's clutch chatter. I have it on my 1990 cummins and it sounds exactly like yours.
Well... I guess we'll see what happens. General consensus is 'Run it!' So that's what I'll do. Thanks for the reply.
2012 MACK CXU PINNACLE (INOPERABLE) (A52472)
2012 MACK CXU...
1999 KENWORTH W900 TANDEM AXLE SLEEPER (A52576)
1999 KENWORTH W900...
2013 CHEVROLET SILVERADO 1500 (A52472)
2013 CHEVROLET...
CATERPILLAR 259D3 SKID STEER (A50458)
CATERPILLAR 259D3...
ITEM LOCATION LOT NUMBER 3 (A53084)
ITEM LOCATION LOT...
2006 INTERNATIONAL 4300 DT466 SBA 4X2 BUCKET TRUCK (A51406)
2006 INTERNATIONAL...
