What size battery for CK30 HSt?
   / What size battery for CK30 HSt? #1
ulflyer
lexington nc
CK 30H
Mine just not holding a charge so I need to replace it. I'm physically challenged at the moment and it would be too difficult for me to pull it out to see whats in there now. If I know the exact size I can buy a battery and maybe get a neighbor to put it in for me.
edited to add: went out to look at it and found that it is a 22F-1. The problem I see is that these come in slightly different sizes whereas the Kioti battery sits in a non adjustable tray so the battery has to be an exact fit. I called the Kioti dealer and their batteries are $106 + tax. I didn't ask the make, but that seems a bit steep.
I guess the only alternative is to get the old one out, measure it exactly, and make the rounds at Walmart, AZ, and Advance.
   / What size battery for CK30 HSt? #2
I have a 24F in my 2004 CK30hst. The length and width fits the tray perfectly and the height keeps it just down from the air filter. I bought it from an Advanced Auto parts store. The 24F is a reasonably common size and can be found in most auto parts stores or probably even a Walmart if you wanted. Mine was 700 cca with 8 year warranty/first 3 years no cost and was $125. There's some less expensive ones but with less CCAs. I wanted the larger for Winter and glow plugs.
Normally the tractors come to the dealer with no battery. The dealer decides which brand and size to install. I haven't seen and "Kioti" branded battery.
   / What size battery for CK30 HSt? #4
I just replaced mine 2 days ago, installed a 24F 700 CCA. The F places the terminals forward of the air filter housing so next time recharging is needed it will be easier access. Any sixe you use will eat up a $100 bill +/- a few bucks. Mine was $98.76 @ TSC with tax.
Dennis, I've never had mine out so I'm wondering if that tray the battery sits in is adjustable in any way? I can't tell by looking at it, but sense many brands of the same group, 22, 24, etc, come in slightly diff widths/lengths, I'm leery of just going to Advance or wherever and buying a 24F. Did you pull yours out first to measure it before buying the new one?
   / What size battery for CK30 HSt? #6
Any size 24 will fit, plenty of adjustment in tray. I used a optima red top to prevent acid from getting all over the battery compartment especially on hilly terrain and vibration. 1 year old tractor Battery tray was all rusted from the cheap POS the dealer put in.
   / What size battery for CK30 HSt? #7
The tray it mine is not adjustable as is in some car types by adjusting a plastic block in the tray. I had measured my original battery and more importantly the tray, so I knew a 24F would fit. The group 34 will, as mentioned, also fit even though a 1/2 longer and 1 inch lower. Mine can't take anything longer than the 24 or 34. The 22 would be not as long and with being smaller, probably less CCAs.
   / What size battery for CK30 HSt? #8
Always install the highest amp hour and highest cold cranking ampacity CCA battery that can be squeezed into the battey box.
   / What size battery for CK30 HSt? #9
This statement is so true if you are up in any area where it gets down to the single digits. More power is a big plus when it is cold out.
Thanks to all for the feedback. I decided to get one from the Kioti dealer, a Deka 750cca, $112 total. When I got the old one out I found that indeed it did have a small adjustable plate at the front bottom held on with two bolts so that it would take slightly different size batteries. Before, there was enough trash covering it that I couldn't see the plate and got all worked up thinking it had to be an exact size. Anyway, got everything thoroughly cleaned, put a couple of those green & red felt washers under the cables to help prevent corrosion and it cranked so fast I could hardly hear the motor turn over. LOL.
2014 FREIGHTLINER CASCADIA 125 SLEEPER (A37757)
2014 FREIGHTLINER...
2004 Ford F-350 4x4 Utility Truck, VIN # 1FDWF37P84ED81730 (A44391)
2004 Ford F-350...
2012 Craftsman YT3000 42in Ride-On Mower (A44572)
2012 Craftsman...
AGT WH12R Mini Excavator (A41852)
AGT WH12R Mini...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A43003)
2019 KENWORTH T680...
Beverage Trailer (A44391)
Beverage Trailer...
