Snow Attachments Adding skid shoes to my Fisher HT plow?
   / Adding skid shoes to my Fisher HT plow? #11
I have had Western and Meyer plows......Never had much luck with shoes on them. They still tended to dig into soft ground
Yup. Shoes are best used as a canoe anchor. A pipe over the cutting edge is a much better solution.
The pipe fix, definitely has merit!
The brackets, which I purchased are not the correct ones, as the portions of the bracket to go toward the blade should be wider to allow them to be perpendicular when installed (rather than narrower).
If I knew the dimensions of the Fisher HT bracket, I could weld an additional piece on to make them conform.
What I need:
I added gussets to both sides of each tube holder bracket. They seem to sit nearly perpendicular to the ground. With all the spacers underneath, the blade is about 1-1/2" off the ground. I'll adjust later, if need be.
2013 Nissan V8 Titan (A57148)
2013 Nissan V8...
40' CONTAINER (A52706)
1994 Chevy Single Axle Dump Truck (A59213)
1994 Chevy Single...
2021 Ditch Witch SK800 Mini Skid Steer Loader (A57453)
2021 Ditch Witch...
500 BBL FRAC TANK (A58216)
500 BBL FRAC TANK...
John Deere 1790 Planter (A59814)
John Deere 1790...
