B21 starts, stalls. Below freezing, Gelled fuel line?
   / B21 starts, stalls. Below freezing, Gelled fuel line? #1
joea99
Marbletown NY
Kubota B21, JD 240GT
Pre-heated, glowed. Started, idled low, quit. Now starts and quits.
Unscrewed and removed fuel filter and fuel only drips out. There is fuel in the tank. I did have water last summer (don't ask) but drained it and ran it for several small jobs after that.
What's a good fuel treatment for this? Do I dare try to heat the hoses?
So a heat gun applied to the inlet started fuel flowing, now warming up. Still, what fuel treatment will fix this?
   / B21 starts, stalls. Below freezing, Gelled fuel line? #3
Power service in the white bottle. About 1-2 oz/5 gallons will work.
   / B21 starts, stalls. Below freezing, Gelled fuel line? #4
There is also a "911" product in a red bottle
   / B21 starts, stalls. Below freezing, Gelled fuel line? #5
What is the temperature?
   / B21 starts, stalls. Below freezing, Gelled fuel line? #6
911 red bottle is for fixing screw ups & frozen fuel. White bottle is for preventing it. If it's a water problem there are some sticks & stuff that will absorb water but not fuel, or you dump/drain the tank.
   / B21 starts, stalls. Below freezing, Gelled fuel line? #7
There is a product from Clean Flo (without w). It's a blue-ish bottle. This product removes moisture.
Since water settles to the bottom of the tank and you have some flow now, just drain a quarter of fuel and it should take the water with it. It doesn't take much to plug the line.
UNUSED FUTURE WALK BEHIND POWER TROWELL (A52706)
UNUSED FUTURE WALK...
UNUSED 30PCS Brown Metal Roof Panels (A53117)
UNUSED 30PCS Brown...
2010 Ford Transit Connect Cargo Van (A53422)
2010 Ford Transit...
2006 Utility 3000R 53ft T/A Reefer Trailer (A51694)
2006 Utility 3000R...
2021 Ford F-150 4x4 Ext. Cab Pickup Truck (A55852)
2021 Ford F-150...
2018 UTILITY VS2RA 53FT REEFER TRAILER (A54607)
2018 UTILITY VS2RA...
